Rangie to Disco Axle swap?
Old Nov 21, 2006 | 01:29 PM
dinandan's Avatar
Default Rangie to Disco Axle swap?
I have a 1991 Range Rover Classic parts truck with a detroit locker in the rear axle. Will this stock rear axle fit (bolt on) under the rear of a 1996 Discovery I'm considering purchasing? Thanks, Dan
Old Dec 3, 2006 | 02:16 PM
Spyderman's Avatar
Default RE: Rangie to Disco Axle swap?
Not 100% sure but I think that the Range Rover axle is wider.
Old Aug 7, 2007 | 05:08 AM
djessopeng's Avatar
The axles are the same width (Disco I was based on the RRC chassis and running gear with a few minor mods) but you may find that the shock absorber mountings on the axle are different as most RRC had the shock absorbers mounted one to the rear and one to the front of the axle casing.
yloDiscoII
Jan 27, 2013 08:31 PM
cationmoted
Oct 19, 2012 07:39 AM
anything old
Sep 24, 2010 02:44 PM
NiteTrain
Jan 20, 2009 03:52 PM
mackfa
Dec 8, 2007 05:53 PM
