Safari Rack
Old Nov 23, 2016 | 07:21 PM
  #21
dparham's Avatar
i made the brackets just pick up some welding steel 2" square tubing from home depot... cut your pieces to your liking " 2" long is what I did and then cut longways to give me 2 pieces of angle basically... then weld on part to bottom of rack with the 90deg against rack bottom and strait bar to fit in channel of disco... then braze or weld on a 3/8" bolt horizontally to that bar so it will have a threaded stud.. then take the other piece of 2" cut angle and flip it over so it hooks under the lip on roof of disco and drill hole to accommodate the bolt... then just get 3/8" specialty cabinet nuts from home depot and your done! ill draw a sketch if u want...
Old Nov 23, 2016 | 07:36 PM
  #22
dparham's Avatar
oops lol I thought you asked about rack I built lol this is different setup that Craft18 used ! so Im not sure... I received email and I thought it was a PM lol
Old Jun 21, 2017 | 06:11 PM
  #23
ccraft18's Avatar
Can confirm.. have had over 400 pounds on the roof rack, no issue at all.
Old Aug 6, 2017 | 01:37 PM
  #24
KingKoopa's Avatar
Could you please expand on your bracket design? I think Ive found the fencing brackets you were referring to but not sure how you adapted them to clamp the drop rail.
Old Aug 7, 2017 | 11:21 AM
  #25
ccraft18's Avatar
Default Roof Rack Brackets.
He's head bolts anchoring to rang gutter, welded steel to bracket
Bracket as mounted to rain gutter. Bottom of bracket clears top of door. Each bracket spaced 3' from one another
One the 90 degree bracket I welded a piece of 1/8'' steel to the bracket itself, it is 1" wide. and is the length of the bracket. I then trilled holes in the piece of steel, so that it fits between the bottom of the rain gutter, and over the rain gutter. In the holes I put to hex head screws to clamp down in the rain gutter. I will post a picture following this comment.
justfred
Apr 18, 2016 03:16 PM
jtysoe
Aug 19, 2008 12:28 PM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
Golden Oliver
Dec 14, 2005 08:52 PM
