Tow hooks?!
Tow hooks?!
I've searched for a good thread but haven't found one. I wonder if there is a good way of adding recovery points or tow hooks without adding after market/arb bumpers. They're a little pricey and personally not a big fan of the look, but would very much like to add some secure recovery points front and back of my 99 disco II for the special situations. Any help/ideas ? I'm sure someone has done this.
The back is easy, assuming you have a receiver hitch. You can get an adapter to put a shackle, or you can just put the strap in the receiver and hold it with the hitch pin.
http://www.okoffroad.com/stuff-receiverbracket.htm
You'll have to buy or make something for the front.
Something like this MIGHT be able to be bolter to the bumper reinforcement. But the jumper might be be string enough. I'm not sure.
http://www.okoffroad.com/stuff-clevis-mount-xd.htm
Something like this bolted to the chassis, behind the crush points, might be better.
http://i1079.photobucket.com/albums/...2012012870.jpg
But then I see photos like that, and I think SOMEONE thinks they are rated for overhead lifting.
