Tow hooks?!
Old Aug 25, 2013 | 02:49 PM
jcox147's Avatar
8th Gear
Default Tow hooks?!
I've searched for a good thread but haven't found one. I wonder if there is a good way of adding recovery points or tow hooks without adding after market/arb bumpers. They're a little pricey and personally not a big fan of the look, but would very much like to add some secure recovery points front and back of my 99 disco II for the special situations. Any help/ideas ? I'm sure someone has done this.
Old Aug 25, 2013 | 02:59 PM
jafir's Avatar
The back is easy, assuming you have a receiver hitch. You can get an adapter to put a shackle, or you can just put the strap in the receiver and hold it with the hitch pin.
http://www.okoffroad.com/stuff-receiverbracket.htm
You'll have to buy or make something for the front.
Something like this MIGHT be able to be bolter to the bumper reinforcement. But the jumper might be be string enough. I'm not sure.
http://www.okoffroad.com/stuff-clevis-mount-xd.htm
Something like this bolted to the chassis, behind the crush points, might be better.
http://i1079.photobucket.com/albums/...2012012870.jpg
Old Aug 25, 2013 | 03:53 PM
jcox147's Avatar
8th Gear
It is equipped with the factory style receiver, which would be great for a D-ring shackle, I did wonder if it was strong enough to handle the load, it looks just a bit different than other receivers I've seen installed. Thank you.
Old Aug 26, 2013 | 01:19 PM
antichrist's Avatar
If you want secure you don't want hooks.
A set of JATE rings would be the easiest.
Old Aug 26, 2013 | 02:23 PM
jafir's Avatar
I mentioned using my JATE rings on my defender for recovery to an offroad driving instructor, and he suggested that they weren't rated for overhead lifting and were cast and might not be suitable for recovery.
But then I see photos like that, and I think SOMEONE thinks they are rated for overhead lifting.
Old Aug 26, 2013 | 02:44 PM
antichrist's Avatar
They are forged, not cast.
Camdisco24
Jan 24, 2015 10:37 AM
ebmorton
Apr 8, 2014 02:39 PM
Rover_Hokie
Off Topic
Jun 19, 2013 10:40 PM
S4poor
Feb 10, 2008 10:15 AM
BamaLandRover
Jul 13, 2005 12:20 AM
