Very confused need help !!!!!!
Hi every one my name is Alexan and I am currently a 2004 Disco II SE7 owner. My Disco is in very clean and great condition. My Disco just made it to 85k miles (all inner city driving) and I want to make some changes to it. I am a little concerned about some of the parts that I have found. I am concerned because I don’t know what parts are quality or good for my car. I just want to give my car one major heavy duty tune up and make over now that I have the chance to so I don’t run into any problems or have to make any changes to it for years to come.
New Tires
Heavy duty rotors
Heavy duty brake pads
Heavy duty calipers
Heavy duty shock absorbers and springs
Heavy duty tune up parts
Tires: Good Year Fortera Triple Tread Size 255/55R18
Rotors: Brembo Sport Rotors Drilled & Slotted (www.brakeworld.com)
Brake Pads: Disc Italia Hyper Ceramic Brake Pads (www.brakeworld.com)
Calipers: A1 Cardone Brake Calipers (www.autopartswarehouse.com)
Shosck absorbers & springs: Discovery heavy duty Bilstein shock absorbers & land rover springs kit
(http://www.roversnorth.com/store/p-6...eavy-duty.aspx)
I couldn’t find a tune up kit
Please if some one is willing to advise me on my situation I would really appreciate it feel free to email me at alexanputrus@yahoo.com or even call 773-640-2339
The changes I want to make are as follows below.
New Tires
Heavy duty rotors
Heavy duty calipers
I did a little research and came up with the following parts
slow down.....
what about the drive shaft? have you had that rebuilt? what about the head gaskets? are you leaking any fluids? coolant/oil or both? check out Disco Mikes 60K service sticky under the disco section. You might want to throw some magnecor 8mm wires and bosch +4 platinum plugs in there as well... i would just do the maintenance sticky then work on from there.
well factor that into your list of things. if you want to rebuild it will cost you under $200. Or you can buy a new one from Tom Woods for around $320. The rear drive shaft also should be replaced.
If you get a chance can you tell me the exact name of both parts you suggested i should change as it is listed in Tom Woods website. Was just on his website little confused on which ones they are thanks
here is a thread on the Tom Woods DS
https://landroverforums.com/forum/sh...ht=drive+shaft
here is a thread on the drive shaft in general
here is the thread on the 60k service that everyone should do.
https://landroverforums.com/forum/sh...ad.php?t=19776
jorgensensc
Mar 22, 2019 09:21 AM
foamwizards
Sep 16, 2011 05:28 AM
