2017 discovery hse lux td6 usa fuel filter change
Old Mar 23, 2020 | 06:57 AM
gmfain's Avatar
Default 2017 discovery hse lux td6 usa fuel filter change
2017 D5 TD6 USA
MAKE SURE ENGINE IS OFF!!!!!!!!!!!!!
(LINK TO PHOTOS AT BOTTOM)
1.REMOVE DRAIN TUBE (READ NOTE ON DRAIN TUBE)((DO NOT RE-ATTACH DRAIN TUBE!!!))
2.PLACE A HAND FULL OF SHOP TOWELS UNDER FILTER FOR SPILLAGE.
3.PRESS TO RELEASE TAB, TO FREE UP FILTER CRADLE.
4.GENTLE PULL ASSEMBLE UP, TO GAIN BETTER ACCESS TO CONNECTIONS.
5.THE CONNECTORS ARE SQUEEZE TO RELEASE TYPE. (NONE ARE UNDER PRESSURE WHEN ENGINE IS OFF)
6.THE SAFETY YELLOW CLIP NEEDS TO SLIDE OVER, TO ACCESS THE SQUEEZE BUTTONS.
7.NOW CAREFULLY PULL UP ASSEMBLE ENOUGH TO UNCLIP ELECTRICAL CONNECTOR.
8.ON YOUR BENCH, US 20MM TORX TO REMOVE PLASTIC CRADLE, RE-INSTALL USING LINE UP MARK ON NEW FILTER.
9.UNCLIP THE BLACK PLASTIC FUEL CATCH/DRAIN FROM THE BOTTOM.
10.IF YOURS HAS THE SENSOR, THEN UNSCREW THE WHITE WATER DRAIN, THEN SCREW IN YOUR SENSOR. USE THE NEW WASHER SUPPLIED ON THE WHITE WATER DRAIN CAP.
11.NOW JUST REVERSE FOR INSTALL.
12.TO PRIME NEW FILTER. PRESS START BUTTON, NO FOOT ON BRAKE. WAIT 30 SECONDS, IT WILL SELF PRIME.( i DID IT TWICE)
13. START UP, AND CHECK FOR LEAKS.
NOTE ON DRAIN TUBE:
IF TUBE IS ATTACHED, AND FUEL ENTERS THE TUBE, IT DUMPS INTO THE INNER FENDER WELL, AND WILL MIGRATE INTO THE CABIN! YOU'LL NEVER GET THE SMELL OUT!!
USE AT YOU OWN RISK. NOT RESPONSIBLE.
LINK TO THIS FILE AND PICS:
https://drive.google.com/drive/folde...9w?usp=sharing
Don't beat me up to bad.
Old Dec 9, 2020 | 10:24 AM
sobiloff's Avatar
Excellent information—thanks!
Has anyone found an aftermarket filter? Dealer wants $170, online prices seem to be ~$130. Given the cruddy quality of diesel here, I'm looking at annual filter changes and cringe at the OEM cost.
Old Dec 9, 2020 | 01:08 PM
gmfain's Avatar
I use this one
https://www.rockauto.com/en/moreinfo...436885&jsn=323
$47.79
Old Dec 9, 2020 | 04:53 PM
sobiloff's Avatar
Originally Posted by gmfain
Dude, that's awesome—thank you so much!
Old Dec 10, 2020 | 04:59 AM
gmfain's Avatar
Your welcome.
Based on my Diesel experience for the past 15 yrs, I change out fuel filter every 20K, its cheap insurance. IMO
Old Dec 14, 2020 | 12:46 PM
ToiletDuck's Avatar
I’m at 35k I probably should. But I would do my Jeep’s eco diesel at 50k and it looked brand new.
Old Feb 5, 2021 | 02:15 PM
christianmotox's Avatar
You replaced the fuel water separator filter, but isn’t there another fuel filter?
Old Feb 6, 2021 | 07:14 AM
gmfain's Avatar
Its all in one unit.
Old May 1, 2022 | 09:22 PM
dirtyhal's Avatar
Default Electrical clip?
Anyone know where to find the metal clip that holds the electrical connector on? I managed to lose mine, put some tape on the connector but would prefer to have it clipped.
Old May 2, 2022 | 06:31 AM
gmfain's Avatar
I was unable to find a part number for the clip. Chances are, you need to go to a dealer to get the part number to order.
