2017 Discovery tailgate/trunk/boot causing problems
Old Jan 13, 2020 | 02:07 AM
Fergus Moroney's Avatar
4th Gear
Default 2017 Discovery tailgate/trunk/boot causing problems
Hello - the electric tailgate/trunk/boot has started acting up. I have the following issues:
- the fold down shelf has stopped working altogether and needs to be operated manually
- open/close with the remote control works intermitently
- open/close with the button under the 'V' works normally
Is there anything I can test before booking the car in with the dealer?
thanks
Old Jan 13, 2020 | 02:08 AM
Chinskij's Avatar
8th Gear
See if everything works fine with car running. And then check for bad ground by the battery see a lot of those bad.
Old Jan 15, 2022 | 08:34 AM
tomex_pl's Avatar
Hi,
Did you manage to resolve your issue? Seems I have the same?
Thanks,
Tomasz
Old Aug 12, 2022 | 05:03 PM
Pecker's Avatar
Hi. Did you get any answers to this I have the same issue. It opens slightly from the key. Perfect from button under the V
Also the small inner tailgate nothing at all. Has to be manual. I did hear a clunking noise almost like something had fell inside the boot when the issue happened
Tx Woody
Old Aug 19, 2022 | 08:51 AM
hevykevy420's Avatar
Had the same issues with my '20, primarily when pressing the tailgate close button the lower tailgate portion would not pull up, the upper would then close and hit the lower/stop 3/4 shut and beep with an error. I have had it in 3 times, the last time they realigned the upper tailgate and resynced the communication modules or whatever they call it. We'll see if it's fixed.
Let's be honest folks, this is just a typical LR superfluous tailgate design that will just turn into a pile of poo. All so we can sit on our tailgate for watching polo matches! 🤬🤷‍♂️
Old Jan 5, 2026 | 11:51 PM
New2LRinCA's Avatar
I have a similar problem. I caused it but can’t figure out what parts to fix it. I was loading the car and the inner tailgate kept raising. I got mad and finally shoved it down. Definitely heard something crack, the. The motor would run and the cable would sort of move the inner tailgate. Finally it all just stopped working. I’m sure I broke some motor off its mount under the driver side end.
And it sounded like something clunking under then floor or inside the rear bumper when it was trying to work.
Did you ever find out what was going on with yours?
Tx Woody
Old Jan 6, 2026 | 02:03 PM
when the lower load door/flap stopped working for me, it needed a new motor. This is the part that retracts/extends the cables to raise/lower the flap. when you search for the part, LR calls it a "strut" in the parts listings/diagrams.
since it has been replaced the tailgate has mostly been functioning as it should.
ponderosajack
Mar 6, 2022 04:05 PM
Novy!
Dec 12, 2019 11:20 AM
buzzybee328
LR4
Nov 4, 2017 03:47 PM
mrtallguy
Jun 25, 2008 03:53 PM
rodrick smith
Jul 18, 2007 09:37 AM
