2018 Discovery Brake Replacement
Old May 27, 2022 | 10:41 AM
BritCars's Avatar
Default 2018 Discovery Brake Replacement
Hi - brake warning light finally come up on my 2018 Discovery after 63,000 miles. Still original pads and rotors. Impressive as our old LR4 used to eat them up about every 25k...
Ordering the parts to do it myself but have to admit I'm very confused by all the part numbers. Looks like there are standard performance and high performance brakes - as best as I can understand as I've got the LR 20inch wheels I have the high performance brakes? Can anyone confirm the part numbers for rotors; pads; and wear sensors for the front and rear for a 2018 Discovery?
Also - it says that brake caliper carrier bolts have to be replaced (torque to yield) - the rear pads picture shows 4 little bolts - so I'm guessing those are replacement carrier bolts for the rears? The front pads for the 20inch don't show bolts in the picture - any idea if they come with them? And if not, what's the right part number as I found SYG000013 but that says it's for the rear calipers.
Appreciate the help. Will report back once I've installed. If anyone has done theirs recently and has any advice let me know - I've done on several Jags and LRs in the past and it all looks pretty standard stuff.
Old Jun 4, 2022 | 06:45 PM
Donc98's Avatar
From my understanding the replacement rear bolts are needed only for the rear carriers. I just ordered 4 from fleabay and found them for $5 a pop. I will wait for them to come in before installing the powerstop z36 kit I just received.
Old Jun 7, 2022 | 09:32 PM
canon_mutant's Avatar
It's early . . . like 3 weeks into our swap I think . . . but this is what I got for our 19.
RockAuto.com . . . reasonable I thought! Hope it helps . . .
DYNAMIC FRICTION ROTORS 60411031 (604-11031) QTY 2 $95.58
DYNAMIC FRICTION 60411030 (604-11030) QTY 2 $147.58
POWER STOP PADS SET Z361692 (Z36-1692) QTY 1 $33.99
POWER STOP PADS SET Z366013 (Z36-6013) QTY 1 $49.89
We had bad front rotor wobbles start during our NM trip and noticeable drop off in braking performance,
It's AH BETTER now.
Put the factory Verdes back on to burn them up. Miss the ATR look but the wife doesn't care about that. I'll buy another set of those Yoko G015s if they are still around. Got 45K out of them. I'm trying to remember SUV tires we got over 40K on before. Struggling . . .
Add in the 4th Time Was The Charm . . . windshield replacement and new wipers, the wife said . . . it's all like new again!
flyingscot
LR2
Apr 9, 2022 08:26 AM
ponderosajack
May 17, 2021 07:06 AM
ponderosajack
Aug 15, 2019 08:40 PM
green_
Sep 18, 2012 08:22 PM
brandodisco
Jan 23, 2008 09:00 AM
