2019 Discovery Rooftop Cargo Carrier Question
Old Oct 8, 2023 | 05:36 PM
Landrovercalifornia's Avatar
6th Gear
Default 2019 Discovery Rooftop Cargo Carrier Question
We have a 2019 Discovery Si6. Has anyone installed cross bars and a cargo box on the factory installed roof rails? If so, what manufacturers are compatible? Both Yakima and Thule 2019 fitting guides state their cross bars will not fit on the Discovery. Yakima may allow use of the Land Rover cross bars but not theirs.
Old Oct 9, 2023 | 10:30 AM
sowrco's Avatar
I bought these from Rhino Rack and use them - they're great, I have a cargo box, max trax holder, awning and a shovel holder mounted to them.
https://www.rhinorack.com/en-us/
Old Oct 10, 2023 | 12:44 PM
Chucktastic's Avatar
We installed a Thule Wingbar Evo on our 2018. They list compatibility on their site. It's a perfect fit.
Old Oct 16, 2023 | 03:21 PM
hevykevy420's Avatar
I bought a set of gloss black roof rails, on eBay, and then sold the ABS roof inserts that come with Discovery cars not equipped with roof bars from the dealer. Selling the inserts (I forget the official name of those parts) covered most of the swap to the fixed rails. I also bought locking adjustable crossbars on eBay, and run a Yakima skybox (and also a cargo basket). The eBay crossbars are <$100. Everything I purchased on ebay looked identical to what you get from the dealership (I even bought a set of fixed running boards on ebay, and they are identical at a fraction of the dealer cost). I am super pleased with my setup, and its pretty quick to install/remove the locking crossbars when you aren't running attachments.
Old Oct 16, 2023 | 03:52 PM
6th Gear
Thanks. Looks like this will work for our 2019 Discovery. Do you have a shark fin antenna in the back? If yes, what cargo box did you put on it?
Old Oct 21, 2023 | 05:13 AM
David42six's Avatar
I'm happy with my Thule wing bar evo.
I tried the Rhino Rack bars and I could not fit them properly and I returned them.
Old Oct 21, 2023 | 04:26 PM
6th Gear
Thanks. The first Thule fitting guide I used stated they did not have cross bars that would work but subsequent inquiries to Thule pointed me to the same system you are using.
Old Oct 21, 2023 | 09:46 PM
TheManMac's Avatar
I bought a $110 set of crossbars on Ebay. They have worked perfectly, are very sturdy, and fit just right. It was nice to save $$$ and still get a good product. I loaded up a borrowed Thule pod onto it and drove 16 hours to the beach and back with no issues at all. The Thule allows you to adjust along the length where the clamps center and clamp down - it can fit a wide range of widths. The cross bars are adjustable width, so you can decide where you mount them on the roof. The front bar is shorter than the rear (the roof rails are curved and get bigger in the back)
https://www.ebay.com/itm/234512195642
sensij
May 23, 2023 11:37 AM
Pa Taket
Apr 26, 2018 08:31 PM
Manbeer
Aug 6, 2017 10:19 PM
DiscoRover007
Mar 4, 2012 03:38 PM
