AC issues 1/2 warm 1/2 cold??
Old Oct 17, 2018 | 01:49 PM
ALScott's Avatar
Default AC issues 1/2 warm 1/2 cold??
Has anybody else had this issue? Drivers side dash vents blowing warm and and passenger side is an arctic blast. Got an appt Monday to take it in. Also said issues with software so I could get the update but service writer just called it "version 4" said he had never heard it called version B, C, etc. Not exactly encouraging.
Old Oct 17, 2018 | 06:49 PM
BritCars's Avatar
I hate to state the obvious, but do you have the ac controls set higher on one side than the other? Try turning temp up high on the cold side and see what happens. Same turning it down cold on the hot side. That will show you if one of the sides isn't working. Then most likely a stick damper
Old Oct 18, 2018 | 07:41 AM
Hayseed_D5's Avatar
Mine did that but the drivers was cold and pass was warm. Dealer found it undercharged from the factory and no leaks found. They recharged and all has been fine.
FlyingZebra34
Oct 6, 2018 07:10 PM
a_wick_2010
LR2
Jun 11, 2015 02:58 AM
FightOnUSC79
Jun 30, 2011 12:52 PM
Tapper
Aug 28, 2010 10:12 PM
VikingDiesel
May 22, 2009 07:34 PM
