Additional Front Lights for 2022 Discovery
Old Oct 1, 2021 | 01:58 PM
Matthew424's Avatar
Default Additional Front Lights for 2022 Discovery
Good Afternoon Everyone,
I would like to purchase auxiliary front lights for my 2022 Discovery. The roads here in suburban NJ get pretty dark at night and deer are all over. I was thinking lights like those below (not a fan of the light bar look):
https://www.roverparts.com/electrica...y-lights/9203/ Admittedly, I have always been a sucker for those circular Hella lights!
However, where to mount? Aesthetically and functionally, I am wondering if it would look better via a roof rack? I found the below roof rack and I like that it has light mounts, and would like to add one rear light as well. Although admittedly I would NOT tackle this type of job. I would have a professional do it right the first time!
https://www.roverparts.com/exterior-...s/VRRD5LOWPRO/
Any experiences with the above lights and/or roof rack? Suggestions? Thanks!
Old Oct 1, 2021 | 02:25 PM
1979rover's Avatar
I plan to go with grille mounted using the mounting tabs from Lucky 8.
Light Mounts
Old Oct 1, 2021 | 02:49 PM
Matthew424's Avatar
interesting. and then where do you connect them for use? Does a separate switch need to be installed?
Old Oct 2, 2021 | 09:57 AM
Ronbo44's Avatar
Default Additional LED lights
Try these by Baja. Mounting is super simple with a license plate alum mount. Tap off the engine compartment battery posts. I used a wireless switch so as not to cut into the wiring and void the warranty. Mounted low they’re good fog lights and can be slightly tilted outward for side illumination. Thanks to DieselRanger for suggesting.
Old Oct 2, 2021 | 12:17 PM
MCKD's Avatar
8th Gear
That looks great! Which wireless controller did you go with?
Old Oct 2, 2021 | 01:18 PM
Ronbo44's Avatar
Default Aux light wireless switch
I went with SpeedTech. Not perfect, you have to remember to shut it off but cutting into LR wiring could void the warranty.
The whole job was quite inexpensive if you do it yourself.
https://www.speedtechlights.com/Swit...rol-switch-box
Old Oct 4, 2021 | 09:17 AM
Matthew424's Avatar
good ideas...thank you!
Jonathan Sauermilch
Nov 1, 2024 08:56 PM
wreckdiver1321
Dec 30, 2012 06:16 PM
DiscoRover007
Aug 7, 2012 05:18 PM
yloDiscoII
Aug 10, 2010 04:21 PM
03discoman
Jul 9, 2010 04:48 AM
