Battery cover clip
Old Feb 1, 2022 | 06:35 PM
BritCars's Avatar
Default Battery cover clip
Anyone good with part numbers?
There is a side panel on the right of the trunk in my 2018 Discovery - with the main battery behind it. It seems to be held in place by some sort of sliding plastic clip that has come detached. I can't seem to get it back on and assume it's broken
Trying to find the replacement part. Any ideas on part number. Not the side panel itself - just the plastic slider that holds it in place
Old Feb 2, 2022 | 09:21 AM
1979rover's Avatar
Not gonna lie. Even when it's attached it's a real PITA to get back on correctly.
Old Feb 2, 2022 | 06:11 PM
BritCars's Avatar
Yes. Seems like a very impractical design to access the battery...
Old Oct 13, 2025 | 04:00 PM
joe2000's Avatar
Default Any luck
Hi mate
any luck, Iv got the same issue
Old Oct 13, 2025 | 08:27 PM
sowrco's Avatar
If mine goes I'm 3D printing something that will work better.
Old Oct 13, 2025 | 08:50 PM
ponderosajack's Avatar
I have attached a short length of flexible wire with a loop end that allows me to slide the sliding latch rearward. And I just reach behind and push it to slide it forward. Yes it’s a poor design but not broken and still usable if you examine it with panel removed and see where the sliding latch is supposed to engage with the panel. You have to remove the smaller rearmost panel first but that’s no problem.
Old Oct 14, 2025 | 01:23 AM
joe2000's Avatar
good shout, Ill give that a go
Old Oct 14, 2025 | 10:52 AM
RyanLR3's Avatar
There's a rectangular notch in the underside of the slider that can be used to slide it back and forth to engage/disengage... Use a flathead screwdriver. Have to look under to see it.
Brandon318
Aug 25, 2023 11:18 AM
grahamggggg
Dec 7, 2020 02:13 PM
Aeteocles
Nov 9, 2019 12:39 AM
pilsner
Jul 14, 2009 11:33 AM
detroit_pierogi
Feb 11, 2006 11:23 PM
