Brembo big brake upgrade for Td6 Discovery
Old 06-20-2022 | 05:03 PM
Seattle TD6's Avatar
Originally Posted by sgapman
Hi Seattle TD6,
I did my brembo upgrade on my 2014 D4, that upgrade includes Calipers, Rotors, splash guards and one wear sensor wire. I am about to buy a 2017 D5 which came with a 4 piston brake, of course I would like to do the same brake upgrade, appreciate if you can share the sources of all components with me , Many thanks.
I retained the Brembo from my D4, it looks the same like what AirRyan posted, unfortunately the part number differ ( LR 016661 vs LR 039524 ), well I guess I will have to buy another pair of calipers then.,
AirRyan lists out all the parts very well above. You need one of everything except the caliper bolts, you need 2, and splash shield bolts you need 4. Then you just buy the pads of your choice. I went with Brembo Sport pads front and rear, they are great but dust like crazy.
Old 06-20-2022 | 10:09 PM
sgapman's Avatar
Thank you Seattle TD6, btw did you replace the pad wear sensor cable ?
Old 06-21-2022 | 10:31 AM
Yes. New ones installed
Old 07-05-2022 | 11:37 PM
Just got back from a few thousand mile towing trip. These brakes make SUCH a difference. Completely different experience, sooo much stopping power and fade resistance. If you tow I cannot recommend this upgrade enough.
Carlos Man
10-31-2019 08:45 AM
CG1
08-30-2019 06:52 AM
Alex_M
04-17-2016 10:15 PM
Antmen
07-04-2013 05:01 PM
Benhamtroll
12-01-2005 04:01 PM
Quick Reply: Brembo big brake upgrade for Td6 Discovery
