changed LR140035 expansion chamber for the air suspension compressor
Old Sep 29, 2024 | 02:05 PM
gmfain's Avatar
Default changed LR140035 expansion chamber for the air suspension compressor
It wouldn't let me raise or lower suspension , also no cruise control or forward alert.
first opened up compressor tested for air leaks, no air leak.
replaced the expansion chamber, fixed it. #LR140035
actual code
pulled the unit
compressor in housing
drilled all rivets out
compressor with both housings removed
part
rivet tool
part came with rivets to reassemble
the filter is also riveted in
inner housing assebled
everything reassemble and bolted in
cover installed
tray and side pieces bolted in
foam back in place.
Hope this helps someone!
took about 5 hours, including air leak testing with soapy water.
Old Sep 30, 2024 | 11:26 AM
CincyRovers's Avatar
Interesting, so that's where the subwoofer is located. According to Meridian, it is located behind the cargo lining on the driver's side. Now it makes sense that I couldn't find it when I had my D5.
Old Sep 30, 2024 | 01:16 PM
gmfain's Avatar
I have the third row seats. That could affect the location.
Old Sep 30, 2024 | 02:15 PM
Chucktastic's Avatar
Our expansion chamber failed a while back and was replaced under CPO. Same symptoms. It seems like it would be a lot simpler repair if the internal hose was just a little bit longer or if the compressor housing was screwed together instead. I guess we're lucky they sell a repair part rather than the whole compressor as a non-serviceable unit.
Also, I'm really jealous of your foam block for the hitch storage. I had the factory hitch installed after the fact and it didn't come with the insert.
Old Sep 30, 2024 | 02:58 PM
I had an HSE Luxury which came with the third row as standard. There's a possibility that it is behind the cargo liner in five-seat vehicles, but I doubt it.
Old Oct 6, 2024 | 07:40 PM
TheManMac's Avatar
Wow! Way to go. Really buried down in there. I've never riveted a thing in my life 😂
Old Oct 7, 2024 | 04:37 AM
gmfain's Avatar
Talking
Its easy, drill old rivet out with a 4mm drill or a 5/32 drill........ the old rivet becomes two pieces, and falls away...... when reassembling, open rivet gun handle wide open, insert rivet into gun...... position into the hole, hold a little pressure inward, close/pump handle, ( usually two pumps) then the stem on the rivet will pop off! ( pop rivet)
No worries.
Good luck!
Old Oct 8, 2025 | 02:10 PM
mc690's Avatar
Default Wish you had video
Every YouTube out there is for different models, and I was under the belief that the compressor was upside down along the side of the body behind the rear wheel.
I have a 2017 discovery L462 with a third row seating as well so I’m going to guess that my compressor is where yours is. And maybe this expansion piece will allow me to return the new compressor I already bought. Unfortunately no one here wants to work on it so I might have to do it myself!
I’m guessing this is why the very next year JLR added a big metal tube as an air tank to this vehicle. The compressor probably was used much more than they anticipated. I believe an air tank requires less compressor usage. The compressor only runs one air tank needs to be refilled.
Old Oct 10, 2025 | 08:32 AM
mc690's Avatar
Default Didn’t disconnect air line
I downloaded the topic document on removing and replacing the suspension air compressor housing. It was adamant to replace the air connectors however it looks like you never disconnected them. I wish you would’ve specified that if it is a case. Is it?
The related thread with link to JLR TOPIX instructions is:
https://landroverforums.com/forum/new-discovery-v-51/anyone-replace-air-compressor-themself-117449/#post937956
Old Oct 10, 2025 | 09:43 AM
mc690's Avatar
Default YouTube Discovery 2017 Air compressor replacement
No speaking—suitable for any language
(Part number shown in English)
