Commute Function in Nav
Old Mar 19, 2025 | 09:37 AM
Elzot's Avatar
Default Commute Function in Nav
As is typical, LR's Owners Guide is quite cryptic.
How does one use the Commute function - i.e. do you have to select/enter a destination first and then activate Commute, or do you activate Commute first and then select a destination?
After activating Commute, I see a button that says "Finish Setup". If I press it, the button disappears but nothing seems to happen.
I see nothing different on the nav screen.
I do have all the nav-related subscriptions.
Old Mar 19, 2025 | 09:58 AM
CincyRovers's Avatar
The commute function automatically learns your daily commutes. So if you drive to the same places every day, it will eventually remember your commutes and give you the option on the nav to quick select the destination without having to manually type it into the system.
Old Mar 20, 2025 | 09:22 PM
Elzot's Avatar
So, i see the Commute function working. Except for one thing: If I push the "Start" button, it starts the guidance to home and shows distance and arrival times. However, there is no voice guidance. It also does not show the impending turns in the dash, as it does with normal guidance. If I stop the Commute and then start the normal Home guidance, voice guidance is there. I assume the Commute function is not intended to be silent?
Old Mar 21, 2025 | 08:11 AM
Now that you mention it, I don't recall voice guidance on the commutes on my old D5 and even my Defender. I could be wrong, but I can verify on my Defender (bear in mind that has a different infotainment system than the 2017-2020 D5) when I pick it up from my service appointment tonight. Despite having two different infotainment systems, they are both very similar in layout and functionality.
Old Mar 21, 2025 | 09:44 AM
Elzot's Avatar
Thanks. Please let me know. It seems odd that there wouldn't be voice. But it is a LR, so....
Old Mar 22, 2025 | 06:32 PM
Can confirm the commute function does not have voice guidance.
Old Mar 22, 2025 | 07:31 PM
Elzot's Avatar
Thanks. That's ridiculous, though. "We memorized your route for you, but we aren't going to tell you about it." Why have a start button for it?
And not only no voice, but also doesn't show next turns in the driver's display.
Nice going, LR. That's stupider than not having a single unswitched USB port in the vehicle.
Old Mar 23, 2025 | 10:24 AM
in2dwew's Avatar
I have guidance configured for a female British voice, but then I never use voice because it always interrupts my music at the BEST parts. Lol. On commute guidance, just tap the icon that looks like 3 sheets and you'll be able to turn voice back on.
Old Mar 23, 2025 | 10:39 AM
Elzot's Avatar
Thanks. I'll give that a try. Nope. There is no option to turn voice on or off. The only option there is type of map - 2D, 3D, etc.
pappagrump63
Range Rover Evoque
Dec 11, 2024 05:11 AM
mlw911
Aug 15, 2022 11:09 PM
Easy3
Mar 16, 2022 11:38 AM
ashmarie73
Nov 27, 2010 12:46 PM
bigswilson
Apr 29, 2008 06:02 AM
