Driveline vibration upon take off
Old Feb 7, 2024 | 10:31 PM
roux's Avatar
Default Driveline vibration upon take off
2018 Land Rover discovery HSE lux
After I take off from a stand still with gentle acceleration and when the car shifts from 1st to 2nd I hear a drive line vibration. If I were to take off with more throttle it does not happen.
it is most prominent if I start to turn left right after take off.
The car is equipped with a rear locking diff.
anyone else experienced similar situation?
Old Feb 11, 2024 | 08:43 AM
bkjecu94's Avatar
Is it more like a 'thump'? If so, I have the same issue and have the rear differential. I have asked my JLR Dealer (Raleigh, NC) to diagnose multiple times, however they have never been able to duplicate.
Time will tell if it is a detrimental problem.
Old Mar 3, 2024 | 04:39 PM
roux's Avatar
Yeah, it is a thump. I’ll update the thread if I find out more
Old May 12, 2024 | 08:39 PM
droolyFace's Avatar
Any update on this?
Old May 13, 2024 | 02:04 AM
adam5's Avatar
I've noticed my 2020 D5 does the same; also equipped with rear locking diff.
Straight-line take-off is fine, but a slow speed (take-off & left turn) causes the slight but noticeable driveline shudder.
Old May 13, 2024 | 10:12 AM
Elzot's Avatar
Is it affected by temperature, either the air's or the vehicles'?
Old May 13, 2024 | 11:48 AM
adam5's Avatar
iirc I generally notice the shudder when the vehicle is cold. i.e. morning start from home, or evening start from work.
Old May 13, 2024 | 12:01 PM
Elzot's Avatar
Perhaps it's related to gear oil viscosity then. It may not be a defect but a "feature" of the locking diff. After all, I have been told by MB that the lag in the transmission engaging when shifting from reverse to drive (and, yes, I do come to a full stop before shifting) is "just a feature."
Old Nov 8, 2024 | 11:08 PM
roux's Avatar
I’m still hunting for a solution for this. I can recreate this at all times regardless of whether the car is warm or cold. I have learned to drive around it for the time being. Taking off with a bit more gas especially when I’m anticipating a slight left turn as I take off makes the occurrence of the shudder less.
it however, never happens when I turn right or take off in a straight line. I wonder whether this has anything to do with the axels
Old Nov 11, 2024 | 09:17 AM
CincyRovers's Avatar
The rear differential clunk is completely normal. The Defender I drove at the LR Experience Center at the Factory in Solihull had a clunking rear diff and the instructor said that it is normal, especially on a car that had 15k miles, all of which were done off-road. I also brought this question to a friend of mine who is a development engineer at JLR, and he said that the clunk is just a little bit of friction and not to worry about it. He said if it gets really noticeable, you should change the fluid. My Defender with the rear diff occasionally has a slight clunk when accelerating from a stop or when setting off and turning. I would recommend changing the rear diff fluid every 30k miles instead of the recommended 64k. I'm at 38k miles, and I changed the rear diff fluid at 32k, and also mixed in a bottle of Ford Motorcraft friction additive with the differential fluid. That has helped tremendously.
Amazon Amazon
marshan1
Oct 12, 2019 04:33 PM
joseosanchez
Oct 23, 2017 10:53 AM
Overfinch580s
Feb 5, 2013 06:51 AM
V6LRF
Freelander
Jan 26, 2009 12:55 AM
LiftedRover96
Feb 7, 2006 10:41 PM
