Driving Over Tall Grass. Bad Idea?
Old Jan 28, 2022 | 05:39 PM
Matthew424's Avatar
Default Driving Over Tall Grass. Bad Idea?
As the title indicates, is it a bad idea to drive over tall grass? During some offroading, I can hear it brushing along the bottom of the LR. I am not worried about it scratching the underside, just concerned that with part of the (hot) exhaust exposed, could it cause a fire? Thoughts??
Old Jan 28, 2022 | 08:49 PM
stillruns's Avatar
Huh? No. Is the grass green? No.
If the ground was bone dry, it was the middle of the Summer and you pulled off the interstate and parked in the middle of a hay field, maybe. Doubt it.
Old Jan 29, 2022 | 10:09 AM
Matthew424's Avatar
thanks
Old Jan 30, 2022 | 09:08 AM
WINOverlander's Avatar
Default tall grass
It depends on the conditions of the area and the grass. Tall green grass in winter, no problem but you’ll be surprised how slick wet grass can be. In the middle of a hot, dry summer, not a good idea. I’m a firefighter and have heard of some fires being started in tall, dry grasses when people idle for extended periods of time or drive through tall dry grass for long distances, but only when the conditions are right (low humidity, dry season, low fuel moisture). Probably not the best thing to do for miles and miles in the summer if you live in a dry season prone to wildfires. Otherwise you should be okay. Just be conscious of the conditions.
Old Jan 31, 2022 | 10:35 AM
Matthew424's Avatar
Understood. Thanks for your thorough response. Stay Safe!!
NewToTheTwo
Jun 2, 2020 05:01 PM
klandrover
Oct 4, 2015 08:42 AM
Shawn Cross
Dec 19, 2012 12:48 AM
Disco2Fever
Apr 18, 2009 10:05 AM
reedster5
Sep 16, 2007 05:44 PM
