Electronic Parking Brake Deactivation/Activation
Old Oct 31, 2019 | 02:49 PM
ponderosajack's Avatar
Default Electronic Parking Brake Deactivation/Activation
The attached file shows how to Deactivate the Electronic Parking Brake Mode for towing or for replacing Rear Brake Pads and how to Reactivate it.
This should be a sticky.
Old Oct 31, 2019 | 03:55 PM
discov's Avatar
Is this also the way to keep it from automatically applying the parking brake when the transmission is put in park? I do not like this feature...
Old Oct 31, 2019 | 05:00 PM
You can try it. Let us know if it works for you and if you can still then apply and release it with the console switch while keeping the auto deployment inactive.
Old Nov 2, 2019 | 12:22 AM
andries's Avatar
These finds are great!
Will definitely download and keep a copy in the glovebox as well.
Should have been in the manual, as it can be needed offroad out in the middle of nowhere if something breaks and a buddy need to tow you, etc, etc.
Old Nov 4, 2019 | 03:58 PM
BalanBro's Avatar
You are the best! I've been looking for this for so long! I have to tackle the rear brakes on our D5, and was concerned I would have to remove the motor and manually wind each EPB unit. While this seems easy enough, my concern was whether it would be out of calibration with the new pads. Service mode is what I needed, but no one seemed to have any info on the procedure, and from what I can tell none of the OBDII diagnostic tools currently on the market are compatible with 2017+ Land Rovers.
Old Nov 4, 2019 | 04:08 PM
Thanks
I did try it and the dash said I was in maintenance mode or something to that effect.
ponderosajack
May 15, 2021 09:59 PM
TEX_Rover
Aug 28, 2017 12:46 PM
Rover Newbie
Jul 9, 2015 06:00 AM
steb4680
Feb 19, 2014 08:19 PM
UpChuck
Aug 20, 2010 09:41 PM
