Front end shockers sag overnight
Old Feb 17, 2026 | 12:51 PM
maviaman's Avatar
Default Front end shockers sag overnight
I have a 2017 First Edition with air suspension. I have lately seen that the front shockers sag overnight. It is almost to bump stops, rear stays fine.
I have lifted the normal height by 1.5 inches with GAP tool.
I removed air suspension fuses to check if the self leveling sensors make both sides sag the same and if there is a leak on one side only. Both sagged the same amount still.
Any one noticed this? any pointers - bad sensor? module?
Thanks
Old Feb 17, 2026 | 03:24 PM
AjjayS's Avatar
Not sure if these work the same but on the LR3s + 4s if they sag together in the front or rear it's usually a valve block. So I'd look into that maybe, how many miles do you have?
Old Feb 17, 2026 | 06:52 PM
maviaman's Avatar
I am at 65k miles
Old Feb 19, 2026 | 08:17 PM
mtaylo32's Avatar
Having this occur at 149K miles. Following for any updates. Mine only happens when temperatures hover around 32 degrees or less overnight.
Old Feb 22, 2026 | 11:38 AM
Kajtek1's Avatar
Rubber age regardless the mileage, so this can be age-related.
This company makes very impressive video clips on youtube, so I saved them. They seem to be in China, but advertise in US, but never had a need to check it.
With the prices some of those air suspension shocks cost, even shipping to China will be small quote in total.
https://www.rsshock.com/
https://www.youtube.com/@airsuspension-u9f
Kfrome
Sep 19, 2025 05:20 PM
TommyBoi
Mar 15, 2025 10:51 PM
lighting
Range Rover L322 (3rd Gen)
Dec 2, 2024 01:45 AM
paulblake
Aug 8, 2020 09:03 PM
cmshoot
Nov 16, 2019 07:53 PM
