Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
2007 Suspension height calibration
Old Aug 8, 2024 | 03:03 PM
lighting's Avatar
Default 2007 Suspension height calibration
Had a leaking issue with the front suspension valve block and replaced, also replaced the tired compressor. Now the suspension is all messed up, left front normal, right front hyper extended, right rear normal and left rear is not lifting. Do I must have the GAP IId tool to calibrate or there's another way or perhaps something else is wrong. Your help will be greatly appreciated........
Old Aug 13, 2024 | 03:13 AM
sjz's Avatar
sjz
Make sure your suspension hight sensor is correctly installed.
It's possible to install it the other way around, where up is down and down is up
I had the exactly same problem and this was the cause. Rotating it 180 degrees fixed all the issues.
Good luck!
Old Aug 17, 2024 | 01:44 AM
lighting's Avatar
Thanks, I will check into that
Old Dec 2, 2024 | 01:45 AM
roverraj's Avatar
8th Gear
Well… did you figure it out?
rich.cash
Aug 26, 2024 09:41 PM
soarvet
Nov 11, 2021 06:36 PM
cmshoot
Nov 16, 2019 07:53 PM
Groucho123
Oct 16, 2018 10:52 PM
kitoko
Dec 19, 2008 08:15 AM
