How to remove rear light assembly?
Old Mar 2, 2020 | 08:42 AM
RobHSE's Avatar
Default How to remove rear light assembly?
Hi - I’ve managed to crack my offside INNER light assembly. Looks like they are a sealed unit and I can’t just replace the outer cover. I’m a bit concerned about removing the tailgate cover on the inside to gain access (I assume I have to). Has anyone got any tips?
You can see the crack in the inner lamp assembly.
Think I need to remove this panel. There is a rubber bung which pops out and gives access to one but and bolt. But I assume it can’t me that easy and the light will have several screw/bolt?
Wonder if there is any fixing behind this panel On the edge of the lamp?
Old Sep 16, 2022 | 12:29 PM
caseyba's Avatar
Default Unplug connector
Hi
How do I unplug the connector have removed the light cluster but cannot unplug the cable
mollusc
Nov 16, 2017 11:59 AM
socal1200r
Jun 1, 2014 04:44 PM
wheelgarage
Oct 1, 2011 03:12 PM
caleb
Jan 6, 2010 11:26 AM
Chrisinhouston
Nov 9, 2009 01:37 PM
