InControl Updates Failing
#21
20A was successfully installed last week. Have had it with no issues.
Today, I am getting a data useage overage message - says to put more data on my plan.
This problem is:
1) I have the unlimited plan
2) Plan was auto-renewed on May 28th
3) Logged in and current useage is well less than 1 GB
Anyone experience this? Does this have anything to do with the system update?
This problem is:
#22
This problem is:
This problem is:
#23
After I upgraded to 20A I have received the same messaging. I have looked into my cellular data settings and it seems that there is a default setting with a data limit of 100MB per month creating the above-mentioned message. You can change the settings based on your plan and the message goes away. I guess this is a new feature in 20A.
#24
astctp@ncscbg.biz (06-01-2020)
#25
#26
I had this message and haven't yet been updated to 20A. I also have unlimited data and set the data limit setting in connectivity settings to off. I toggled it back to on and set a high limit and still received the message. I was still getting traffic data for the maps but the weather would not work. It seems to have resolved itself as I did not see the message today.
astctp@ncscbg.biz (06-03-2020)
#27
#28
I've had dealer do them at annual service and always worked fine for them. System has improved a lot in 18 months
TeamEdition - how are you using Bluetooth and CarPlay? I thought it only works on a cable? I use it a lot (by cable) and it works perfectly. My only gripe is there isn't more control over the screen layout and choices - but that's an Apple issue. I use waze and Spotify all the time.
the Apple CarPlay screen layout and app choices is done through the Settings menu of your iPhone. On your iPhone, go to Settings>General>CarPlay>Land Rover Discovery>Customize
There you can Add, Delete, and rearrange the order of the apps displayed on your Rovers screen. If you do this while CarPlay is currently displayed in your car, you can watch it affect as you reorder stuff
angelboing (09-04-2020)
#29
2018 Disco5 HSE LUX Just bought from dealer with 32k mi. Went to set up the InControl app but no ability to connect to the internet hot spot or normal wifi. Dealer could not connect either to do an software update. Said it is a a problem with the I. M. C system, which is your info screen and actual modules assembly. Said the wifi is not becoming available because the actual wifi does not know to turn itself off and thus cannot get it to download manually - Said they are going to have to escalate the case now with J L R north America, Any one have experience with not being able to connect WIFI and any successful outcomes ? Thanks very much if you take time to post.
tgras1
05-16-2018 01:51 PM
