IPhone won’t connect via USB
Old Sep 25, 2021 | 05:05 PM
ToiletDuck's Avatar
Originally Posted by Spacepig
I replied to someone else on this forum, this is a bug from InControl Touch Pro (latest version) and CarPlay. This turned me nuts too but someone found a workaround, that actually works for me: You need to have your Phone with at least 50% of battery left otherwise you will enter in a Connect/Disconnect loop with CarPlay. And it works. Each time my phone is below 50% it craps out, above 50% everything is solid as a rock and I never disconnect.
I found this trick on RangeRover.net forum someone with a L405 had the same issue and another guy advised to be at least running an iPhone with 40% battery. In my case, it only works around 45~50% minimum.
Thank you! I didn’t m is if I should take it to the dealer. My iPhone 12 mini is also having a bad battery issue where it’s already at 88% capacity I had wondered if Smart Charging could have been doing it. The iPhones limit how they draw power to help save the battery so wondering if that didn’t fly with the USB system.
ToiletDuck
Mar 15, 2022 10:05 AM
Bigds011
Jan 5, 2019 08:58 PM
Amanda Evelyn
Dec 25, 2018 12:56 AM
npach82
Aug 8, 2018 05:12 PM
riminirover
LR2
Jan 12, 2009 10:09 PM
