Question: Playing music through phone, directly plugged through USB port
Old Jul 30, 2018 | 03:16 PM
npach82's Avatar
Default Question: Playing music through phone, directly plugged through USB port
I recently purchased a disco 5 and tried playing music through my phone while directly plugged into the USB port. The music plays through the cars sound system but at a faster pace and a higher pitch. Has anyone else run into this same issue?
Thank you for your time.
Old Jul 30, 2018 | 06:32 PM
That's wild
Old Jul 30, 2018 | 06:39 PM
MikeinNY's Avatar
Haven’t had that problem. I’m much happier not plugging the phone into the USB ports in the center console that connects to the InControl system. Just power it from a dumb usb port and connect through Bluetooth audio. That has been rock solid for me. No more apps and phone fighting for control.
Old Aug 1, 2018 | 01:09 PM
vulturez's Avatar
Are you not also connected via bluetooth? I am fairly certain that the audio streams over bluetooth while the InControl system communicates via the USB tether. Try disabling BT on your phone, and seeing if the music streams. If it does not, remove your vehicle from your phone's BT memory, and then pair it with the system again. If when you disable BT the music still streams, enable BT and pair with your vehicle to see if that fixes your audio issues. I would also recommend power cycling your phone prior to trying this.
Old Aug 1, 2018 | 05:37 PM
1979rover's Avatar
I found this true as well. I use the dumb USB power below the cupholders (seems to charge faster too) and connect via Bluetooth.
Old Aug 8, 2018 | 05:12 PM
SoCalWiley's Avatar
Same here, I put a charger in the 12v in front of the cup holders with a short power cord and the phone sits in the tray connected via bluetooth. No fuss.
I tried the connected USB and sometimes it doesn't connect and says to unlock the phone or unplug/re-plug the phone.
BritCars
Jan 11, 2019 09:05 PM
BigTim
Sep 5, 2018 03:50 AM
tthrush
Aug 25, 2010 05:48 PM
patentman
Sep 9, 2008 09:43 AM
Tommy Boy
Jun 19, 2007 09:28 PM
