Just received recall for Battery Ground Stud
Old Dec 26, 2020 | 09:29 AM
AirRyan's Avatar
Default Just received recall for Battery Ground Stud
Not the end of the world, but I was under the impression that my truck already had the fix. They say they can do it in half an hour (billable time is 0.2 hour, that's 12 minutes.) so I might schedule a time when they can otherwise get on it while I wait. Nice that they at least made an improvement and are implementing it before you could possibly get stranded.
https://www.nhtsa.gov/vehicle/2020/L...UV/4WD#recalls
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Dec 26, 2020 | 07:24 PM
canon_mutant's Avatar
Yup, we battled this for 6 mths. Two batteries, cable, terminal, and finally the ground stud. I asked them early on about the new aluminized chassis if perhaps there might be a dissimilar metals corrosion build up over time or something but never got an actual answer. The last thing they did was just swapping the actual ground stud. Good news is [knock on wood] we have not had DOA since the stud swap.
Old Dec 27, 2020 | 10:06 AM
LoneStarLR's Avatar
Reading the tech guide for installing a new stud, I’m curious as to how this fixes the problem? It it’s a time based corrosion thing why wouldn’t the problem happen on the new stud?
if it’s a case of some studs being badly fitted at the factory (whatever badly means) what stops the dealership from tech doing a bad job of it and even creating the problem on vehicles that didn’t have the issue to begin with?
Or did I miss the details on the exact cause of the problem re the stud and the exact fix of the new one?
Old Dec 27, 2020 | 11:28 AM
DeusMexMachina's Avatar
Same thoughts here. Reading the Tech Bulletin it seems the procedure only moves the location of the ground stud.
It’s not in the Bulletin but I remember a star washer being a remedy.
I didn’t experience the problem but the dealership made the fix last time I was in for service.
Old Dec 27, 2020 | 01:16 PM
Groucho123's Avatar
I had some issues a couple of months back with the info/radio system shutting down every once in awhile. They traced it to the battery and it's connections.
Old Dec 27, 2020 | 01:23 PM
LoneStarLR's Avatar
I got the notice yesterday, so I’ll have to get it booked in as I’m like 6 months from the next annual service...
Old Dec 27, 2020 | 04:24 PM
ponderosajack's Avatar
The recall is for 2019 ad 2020 model years. So whatever they did on the 2017/2018 models evidently was different. Haven't had any issues on my 2017. Hope I didn't jinx it.
Old Dec 27, 2020 | 06:25 PM
LoneStarLR's Avatar
2017 and 2018 were built in UK.
The changeover to Slovakia was early 2019 I think?
New plant, new problems?
Old Dec 27, 2020 | 10:10 PM
Our 2019 was one of the last ones from the UK.
Old Dec 31, 2020 | 05:55 PM
LoneStarLR's Avatar
I had it booked in for this afternoon, took it in and the tech had it done in 30 mins.
greisinb
Nov 28, 2020 08:56 PM
Disco Eagle
Mar 10, 2019 05:30 AM
lostl13
Jun 6, 2013 08:40 PM
Draayer
Mar 30, 2012 10:39 AM
Hussy
Oct 4, 2011 05:27 PM
