Just received recall for Battery Ground Stud
Not the end of the world, but I was under the impression that my truck already had the fix. They say they can do it in half an hour (billable time is 0.2 hour, that's 12 minutes.) so I might schedule a time when they can otherwise get on it while I wait. Nice that they at least made an improvement and are implementing it before you could possibly get stranded.
https://www.nhtsa.gov/vehicle/2020/L...UV/4WD#recalls
Yup, we battled this for 6 mths. Two batteries, cable, terminal, and finally the ground stud. I asked them early on about the new aluminized chassis if perhaps there might be a dissimilar metals corrosion build up over time or something but never got an actual answer. The last thing they did was just swapping the actual ground stud. Good news is [knock on wood] we have not had DOA since the stud swap.
Reading the tech guide for installing a new stud, I’m curious as to how this fixes the problem? It it’s a time based corrosion thing why wouldn’t the problem happen on the new stud?
if it’s a case of some studs being badly fitted at the factory (whatever badly means) what stops the dealership from tech doing a bad job of it and even creating the problem on vehicles that didn’t have the issue to begin with?
Or did I miss the details on the exact cause of the problem re the stud and the exact fix of the new one?
Same thoughts here. Reading the Tech Bulletin it seems the procedure only moves the location of the ground stud.
It’s not in the Bulletin but I remember a star washer being a remedy.
I didn’t experience the problem but the dealership made the fix last time I was in for service.
