MAP sensor Replacement
Old Apr 25, 2025 | 09:55 AM
soarvet's Avatar
Default MAP sensor Replacement
Hey guys. I just had to replace my MAP sensor on my 2020 3.0L Diesel. I changed my oil and made the bonehead mistake of blowing air in the MAP sensor to clean it out. I know I've seen @gmfain reference this. Just got to moving too fast and wasn't thinking. Anywho, Landrover wanted $305 for a new one. They're about $100-$110 on Rock Auto. I started digging. If you look at the MAP Sensor it's got FoMoCo on it. Well damn, started looking at ford motor company MAP sensors and found that the sensor for the 6.7L power stroke is the same as the 3.0L There's a lot of cross reference numbers. You can get the sensor from Ford or Amazon for as low as $84. Figured I post that up in case anybody runs into this issue and has to replace a MAP sensor. Also, I found out that you can't reset your oil service with the car throwing a code relating to the MAP sensor. Tried multiple times to reset the service reminder/light. Once I replaced the MAP sensor it showed 16000 miles to next service. Hope this helps somebody in the future.
Search on amazon for:
Motorcraft - CX2432 Sensor
Brand: Motorcraft Brand: Motorcraft
Old Apr 25, 2025 | 10:07 PM
gmfain's Avatar
RockAuto is my goto $68
https://www.rockauto.com/en/parts/mo...)+sensor,11207
Old Apr 25, 2025 | 11:26 PM
adam5's Avatar
I plan on giving this a shot. ymmv
Hitachi PRS0019 MAP Sensor $42
Amazon.com: Hitachi PRS0019 Manifold Absolute Pressure Sensor : Automotive Amazon.com: Hitachi PRS0019 Manifold Absolute Pressure Sensor : Automotive
CHAD5WRX
Sep 29, 2025 08:16 PM
journeyman
Nov 20, 2023 04:13 PM
jasonstaczek
Aug 8, 2023 06:32 PM
klandrover
Apr 5, 2016 12:50 PM
thehun
Oct 5, 2011 11:21 PM
