Not shifting past fifth?
Old Feb 22, 2020 | 09:20 AM
ToiletDuck's Avatar
Default Not shifting past fifth?
Anyone know anything about this? I’m trying to pass two vehicles and at 87mph it starts just limiting out around 4500rpm like its try to shift but can’t. I had it in getting software upgrades and wondering if this did it. In S mode I can shift it manually to go fast (did a long country road test). It will shift past fifth when cruising but not when accelerating.
when pulling my boat yesterday it wouldn’t accelerate once at a normal speed. You could mash it to the floor and the RPMs wouldn’t move at all. You could up shift or downshift and it would stay at it’s current RPM. Thoughts?
Old Feb 22, 2020 | 01:18 PM
LoneStarLR's Avatar
Sanity check: did you accidentally activate the speed limiter?
Old Feb 23, 2020 | 10:04 PM
ToiletDuck's Avatar
in manual I can go 120.... so I’ve heard. Where would this be? Never heard of it!
Old Feb 24, 2020 | 07:05 AM
LoneStarLR's Avatar
I forget what the button looks like, might say limit on it? On the steering wheel I think.
Old Feb 24, 2020 | 04:43 PM
andries's Avatar
Not sure if that is the issue, but here is the info on the Speed Limiter and Adaptive Speed Limiter (if fitted).
https://www.ownerinfo.landrover.com/.../proc/G2162045
You may have to get the firmware updated on the PCM (that is what they called it when they updated our Si6 gearbox software for the lag at low speed rolling stops).
Old Feb 25, 2020 | 10:56 PM
ToiletDuck's Avatar
did it make a difference?
Old Feb 25, 2020 | 11:58 PM
andries's Avatar
The PCM update fixed the rolling stop lag, works as it should now.
bcolins
Dec 9, 2013 03:56 AM
gman21
Feb 18, 2013 02:40 PM
Hirley Issayana Diaz
Mar 22, 2012 04:32 PM
RabbiCP
Jun 4, 2011 12:39 PM
DiscoRom
Nov 22, 2008 02:09 PM
