Oil Change
Old Feb 10, 2024 | 01:33 PM
the ex Flying Dutchman's Avatar
8th Gear
Default Oil Change
Hola: We are in Mexico with a 2017 Discovery 5 HSE TD6. The car is indicating service/oil change. The nearest dealer is 5 hrs driving away. I have asked them for recommendations to do it here in PV, but no replies.
Any tips? Can I postpone until we get to the US in a month and a half? (give or take 4000km/2500mi) Or just get a local oil change?
Old Feb 10, 2024 | 02:17 PM
BritCars's Avatar
How many miles / how long since last oil change? If it's indicating for 16,000 miles (the service interval) then I would do sooner.. if it's just a year and you have lower mileage since last one I'd wait
It's an easy job for any one to do. Vacuum out and back in. But need to get the right oil and the LR spec at least for gas engines is hard to find. Not sure about diesels. You could also just do an appropriate fully synthetic then have the dealer change it when you get back.
Old Feb 10, 2024 | 05:28 PM
LR disco 5's Avatar
Diesel oil is pretty easy to find off the shelf the mobile 5w30 esp works well and is up to spec.
Old Feb 11, 2024 | 08:21 AM
8th Gear
What are the minimum specs? I saw a long post on another page, but I have little or no knowledge of oil.
Old Feb 11, 2024 | 09:37 AM
LR disco 5's Avatar
Im not the right guy to ask about oil I don't have much knowledge I just follow what @gmfain recommends
Old Feb 11, 2024 | 11:28 AM
ponderosajack's Avatar
I would suggest the owner’s manual
Old Feb 11, 2024 | 11:29 AM
Hey. Why does it say Recovery Vehicle after jmy name? I don’t think I set that up.
Old Feb 11, 2024 | 02:19 PM
bkjecu94's Avatar
I believe that is based on your forum interaction.
Old Feb 11, 2024 | 03:20 PM
8th Gear
I think it does 12000km.
The car has 120k km on it.No idea what spec diesel oil I should be looking for besides 5w30 synthetic
Old Feb 11, 2024 | 07:19 PM
gmfain's Avatar
Mobil 1 ESP 5w-30 meets the spec
Since it is a Ford engine, the MOTORCRAFTXO5W30QFAFull Synthetic Diesel; SAE 5W-30 meets the spec
change every 7-8k ..... not 16k not 16k
The Castrol oil is only available by the barrel and or at dealers.
I hope this helps.
