Oil Change
Old Feb 12, 2024 | 04:08 PM
gmfain's Avatar
Here is the 2017+ spec.
Not sure how many years it covers.
File Type: pdf
Old Feb 13, 2024 | 10:10 AM
rnmcguire's Avatar
The OEM recommended Castrol Edge Pro is available online from Atlantic British ($15). It's an ACEA C1 spec oil (Low SAPS / Sulphated Ash). You can also find Ravenol from Blauparts which is also an ACEA C1 spec oil. The Ravenol is quite a bit cheaper. I'm only using ACEA C1 oil in mine. Blauparts has a Ravenol oil change kit for $95 which includes the filter, rubber o ring and 6 litres of oil. The Mobil 1 is a C3/Mid Saps oil which is not as friendy to your DPF.
Old Feb 14, 2024 | 07:11 AM
AtlanticBritish's Avatar
LR Forum Vendor
We have an oil change kit with the genuine castrol oil as well, plus replacement drain plug also included.
__________________
Old Feb 14, 2024 | 07:25 PM
LR disco 5's Avatar
c3 should be working fine and c1 has way less protection for your engine compared to acea c3/c2 I care much less about the dpf because i drive highway 5 days a week and it gets its work in. LR time documented using a higher level of oil
Old Feb 16, 2024 | 12:04 PM
the ex Flying Dutchman's Avatar
8th Gear
Gracias compadre :-)
Juancl
Nov 30, 2024 03:20 PM
skyfi-evo
Jul 11, 2024 03:11 PM
SpyHop
Oct 13, 2023 09:06 AM
djkronik57
Mar 17, 2017 10:28 AM
roverboy
Dec 4, 2008 07:53 PM
