Parking Sensors Active While Trailer Connected
Old Sep 22, 2018 | 09:47 PM
The DareDevil's Avatar
Default Parking Sensors Active While Trailer Connected
The rear parking sensors go nuts when I’m backing up my trailer. Should the truck disable them automatically? My previous vehicle would go into a ‘trailer mode’ and disable them.
Old Sep 23, 2018 | 04:30 PM
roughbeat's Avatar
6th Gear
I've had this same problem with my trailer. I was thinking that maybe we need to use the Land Rover Trailer Assist Sticker in order to get that sensor to turn off automatically? But I haven't tried this yet.
Old Sep 23, 2018 | 08:52 PM
SoCalWiley's Avatar
When I had my hitch installed, the service center installed the tow assist software even though I don't have the pop-up rotatory dial. The first time I connected the trailer, it asked for all the measurements and tried to calibrate with the sticker I didn't have. LR hunted one down for me and even delivered it to my house (though it was a used one and pretty beat up). Once that was stuck on, I got a split-screen left and right trailer view (which sadly only works at low speeds), backup-path lines as well as automatic shutoff of the reverse sensors. The setup has been working well, ask the service center if they can install the software if you tow a trailer.
On a side note, if anybody knows a hack to keep the trailer camera view on while driving that would be great (there was a service-mode hack on older models to allow camera views to remain on at all times). The trailer camera view uses the cameras in the mirrors to look down the side of the trailer with a broader view than the mirror. Basically virtual tow mirrors.
Old Sep 24, 2018 | 12:34 PM
Thanks for the responses guys. Today the truck disabled the sensors and noted a trailer was connected. Later in the day, it wasn’t detecting the trailer. I’ll have to figure out what’s causing it.
Also, I don’t have any of the advanced trailer assist options, just the factory tow option.
Old Sep 24, 2018 | 02:28 PM
SoCalWiley's Avatar
The first time I connected my trailer, it wasn't detected and I didn't think anything of it since I wasn't expecting the pop-up. After towing the trailer from where it was stored to my garage I found that the 7-Pin electrical wasn't fully seated. I found that when it feels like it's plugged in, I have to push a little harder and it will go further in. Subsequently, I've pushed it in harder and it's been detected every time and pops up the trailer connection window.
Old Sep 24, 2018 | 03:03 PM
Interesting, I'll double check. I feel like it would have to be a connection issue given the intermittent nature of the problem.
Oddly, the parking sensors are sometimes disabled, even without the trailer connected. Not sure why!
Not to change the subject, but I sure do miss my diesel! the Si6 is far from a tow master
LADEROUTE
Apr 30, 2024 08:43 AM
Danny Lee 97 Disco
Oct 26, 2011 08:19 PM
mmck0309
Jul 5, 2011 10:44 AM
oljohnboy
Nov 29, 2010 04:14 PM
bamarover
Apr 25, 2007 05:34 PM
