Proud Rhino A-Bar
Old May 1, 2022 | 02:22 PM
Matthew424's Avatar
Default Proud Rhino A-Bar
Hi Everyone,
Does anyone have experience with the Proud Rhino A-Bar for the D5? Not only use but also installation? Easy to install? Thanks. -Matt
https://lucky8llc.com/products/proud-rhino-a-bar
Old May 1, 2022 | 09:08 PM
gmfain's Avatar
I installed it. I like it. Check out my build thread for installation.
Old May 4, 2022 | 07:59 PM
Matthew424's Avatar
great build thread...thank you!
Old May 13, 2022 | 02:21 PM
Donc98's Avatar
i just finished the install of the A bar, hidden winch mount, winch, and bash plate last month. It was a bit interesting but can be done at home. Please be aware that the brackets for the A bar appear to have been updated. each bracket is now two parts that bolt together in the middle. I found that I could not reattach the bumper cover with both brackets in place so I needed to remove just the outer portion of one, install the cover, and then reach in to the bumper cover to attach the rest of the bracket. A bit tight and I needed a short wrench to be able to fit in there beside the winch.
Old May 13, 2022 | 02:26 PM
Matthew424's Avatar
looks great!! If just installating the A bar, do you still need to remove the bumper cover?
Old May 13, 2022 | 02:29 PM
Donc98's Avatar
Thank you! Sadly yes that bumper cover needs to come off (Even called Erik at LKY8 to verify). If you need the instructions from Topix I have them download and can send them over to you. The A Bar support brackets need to bolt into the main bumper support and the only way to get to that is with the cover off.
Old May 13, 2022 | 02:53 PM
Matthew424's Avatar
ugh…that’s what I thought…yes can you send it to me? Mjnoumoff@gmail.com
Old May 13, 2022 | 03:06 PM
Donc98's Avatar
Just sent you the info and some more detailed pictures.
Old May 13, 2022 | 03:15 PM
Matthew424's Avatar
got it…thank you!
Rd929
Dec 10, 2025 07:12 PM
abran
Oct 5, 2018 03:39 PM
fire1427
Audio/Visual Electronics
Jul 3, 2007 05:20 PM
