Rear Camera Missing Yellow Lines
Old Jul 23, 2024 | 06:18 PM
itsNate's Avatar
4th Gear
Default Rear Camera Missing Yellow Lines
Hello all! Just picked up a 2019 Discovery V HSE which I’m loving so far (retired my 2010 LR4 with 300k). One small issue compared to some others I test drove is I’m not seeing the yellow lines on the backup camera.
I have a new GAP IID tool arriving soon and I’ll check for codes, but haven’t see any other error messages.
Anyone know how I can activate those lines or if there’s a problem? I figured the button on the left side should turn them on, but it doesn’t, I also don’t see anything in the camera settings.
Old Jul 27, 2024 | 07:50 AM
bkjecu94's Avatar
I had the same issue and my resolution was tapping the lower left icon in your picture. Looks like you did try that.
Old Jul 27, 2024 | 09:25 AM
FujiJLR’s's Avatar
7th Gear
Your parking guidance is turned off, go to camera settings and turn it on.
Old Jul 29, 2024 | 05:55 AM
bkjecu94's Avatar
I figured it out... put the car in reverse, then tap the lower left icon.
I hope that works for you.
Old Jul 30, 2024 | 10:00 AM
Elzot's Avatar
In your photo, the "parking finder" light (lower right of screen) is lit. This mode is for locating a parallel parking spot the SUV will fit in. Tap the button next to it - the P with the radar lines. That turns on the parking assist lines for regular parking.
Old Aug 1, 2024 | 04:25 PM
itsNate's Avatar
4th Gear
thanks for the responses all, @Elzot I do have this button selected, is it a different one I should be selecting?
I also checked the codes, I see the one below, anyone know if this is responsible for those lines?IPMB-Image Processing Module 'B'
  • U2300-56 (6C) Central Configuration - Invalid / Incompatible Configuration
Old Aug 1, 2024 | 04:33 PM
Elzot's Avatar
In this picture, the correct button is selected. I see the screen is otherwise a bit different in mine. I don't have that other rear "track" icon on the left.
Old Feb 25, 2025 | 03:51 PM
jimmie86's Avatar
6th Gear
Did you found solution?
Old Feb 25, 2025 | 09:25 PM
RyanLR3's Avatar
Have to go into camera settings and turn on park guidance.
Old Apr 2, 2025 | 09:55 AM
jimmie86's Avatar
6th Gear
Nope. i have the same problem as OP. U2300-56 and no tracking lines. I can select, unselect whatever i want - no lines.
Funny part is that tracking lines shows up at camera view for few seconds after ignition on.
I tried 'As built' CCF upload, checked all camera and parking aid related settings, in some cases i just lost cameras completly, but nothing helps,
