Replacing Spark Plugs
Old Oct 16, 2024 | 11:56 AM
devgrinder's Avatar
5th Gear
Default Replacing Spark Plugs
Some beginner questions about spark plugs ...
- am I correct that the 2023 Discovery V takes six spark plugs?
- am I correct these should be changed by 60,000 miles?
- is this something someone without auto mechanic experience but eager to learn could do themselves?
- if this is something you can do yourself, are OEM spark okay or should I consider other brands? and what tools would I need?
Thanks!
Old Oct 16, 2024 | 07:09 PM
gmfain's Avatar
I would go with NGK 93710
You can do it!
Old Oct 17, 2024 | 08:49 AM
devgrinder's Avatar
5th Gear
Thanks for the vote of confidence! I'm going to give it a try!
Old Oct 17, 2024 | 11:17 AM
adam5's Avatar
if you can, post pictures of the process for posterity.
Old Oct 17, 2024 | 05:28 PM
ponderosajack's Avatar
My contact at LR who is very honest with me told me changing them at 60K wasn't really necessary. That said, I plan to do it at 80K. I would also suggest NGK plugs that match the OEM specs. You should be very careful no dirt gets into the engine after you have removed a plug - I would connect a small tube to a vacuum and suck out around the plug before removing it. You should hand thread the new plug into place (with any extensions you need) to be sure it isn't cross threaded before torquing to the spec. Also check the gap on the new plugs to be sure they are correct. The hardest part of the job will likely be access to the rear plugs but I haven't done mine yet so maybe you will be happily surprised. Please see the attachment.
File Type: pdf
Old Oct 17, 2024 | 06:20 PM
462disco's Avatar
2023 is no longer the AJ126 V6, it's the AJ300 Ingenium motor. Plug replacement guide will be different.
Old Oct 17, 2024 | 07:37 PM
And my spark plug instructions pdf will also be different. Sorry
Old Nov 20, 2024 | 01:16 PM
Rover06's Avatar
You can do it!
Surprised there is no other mention of spark plugs in this forum! Perhaps very few bother with anything other than the OEM ones from the dealer. Can anyone confirm if the OEM Land Rover ones in our cars (Si6) are actually this NGK one below? The 93710 quoted above has a heat rating of 8 while this one is a 7 which is what the auto sites show as the OEM replacement. I don't mind saving a few bucks buying the equivalent NGK one instead of ordering from the dealer. I wasn't sure if the .032" gap listed for these is what the OEM plugs are..
NGK 93476
https://www.autozone.com/external-en...476/797687_0_0
Old Nov 20, 2024 | 01:45 PM
gmfain's Avatar
NGK 93476
https://www.rockauto.com/en/moreinfo...t=7212&jsn=335
Just give the dealer a call they can verify the gap, you can check it......... my experience with NGK from Rockauto, has been 100% correct.
Old Nov 20, 2024 | 04:46 PM
Here’s what I found out from NGK earlier this year. This is for my 2017 Si6.
whiskeynipple0088
Sep 13, 2023 12:24 AM
ourx15
LR2
May 17, 2022 11:53 AM
Kushan Gunawardane
Jun 10, 2021 09:18 AM
cpn LR
Nov 20, 2010 10:02 PM
SpeedAgent
Jul 27, 2007 01:20 PM
