Sensors Muted while reversing and parking
Old Nov 21, 2019 | 09:09 AM
Shadi Atshan's Avatar
4th Gear
Default Sensors Muted while reversing and parking
The sensors are working properly as seen on Camera, however voice is always muted. Even if you increase the volume key, they are still muted!
Can anyone advise on how to resolve this problem?
Car is Disco 2017 HSE.
Old Nov 21, 2019 | 06:27 PM
ponderosajack's Avatar
You probably know this but you must adjust the volume while the sensors are making the sound.
Old Nov 24, 2019 | 02:50 AM
4th Gear
I tried. Changing the volume does not change anything !. Volume indicator does not even appear on the screen.
Old Nov 25, 2019 | 10:42 AM
Jhartz's Avatar
I think this is the way it is designed to work. When backing, all volume is muted in order to hear the warnings. That's how it worked on my last RRS and on my current Continental.
Old Nov 26, 2019 | 04:06 AM
4th Gear
In my case, the sensors are not producing any sound at all. Not only while backing.
I dont know what to fix, is it a Fuse issue, does it need reprogramming, maybe a battery ! its confusing.
Old Nov 26, 2019 | 09:59 AM
Jhartz's Avatar
Now I am totally confused: how do you know they are working if they are not making any sound? So the camera works: good. Not the same system. Sounds like a blown fuse or broken wire. Any sound from the front sensors?
"Voice is always muted," is an English translation failure. The sensors are not making any sound. Please put your location in the upper right hand box. Often in these, and Jaguar forums, it is useful to know that the originator of the thread is not a native English speaker and we can then ask for clarification. "Voices muted" means the radio speakers reduced volume while the parking aids were beeping . . .
Old Nov 27, 2019 | 04:52 AM
4th Gear
Sorry for the English translation confusion.
Yes, the problem is: Parking Aids are not beeping at all.
However, you can hear a small beeping sound if you place your ear next to the sensor.
Is this a Fuse problem?
Old Oct 20, 2020 | 04:35 AM
Blanchaa's Avatar
Default Solution
Did you ever get this issue sorted? I have the same problem.
Old Oct 30, 2020 | 06:15 AM
FormerTouaregFan's Avatar
There is supposedly a setting for this. I have the opposite problem and need to shut them off. When driving off road in high brush, the sensors are going off like crazy. And when backing up with a trailer, it drives us nuts!
Old Oct 30, 2020 | 07:10 PM
BritCars's Avatar
When the parking aid screen comes on (the one with the overhead sketch of the car and orange or red bars where you're getting close to something) there is a volume icon in the bottom left. Touch that to adjust sound levels
kurtisblo
Jun 14, 2024 10:55 AM
jrf07d
Dec 13, 2017 10:35 AM
Jnj
Mar 27, 2015 09:13 AM
Land_RAWRver
Apr 16, 2011 10:47 PM
topel98
Nov 18, 2007 06:48 PM
