Towing with D-V?
Old Dec 20, 2017 | 03:46 PM
turnbaugh's Avatar
Default Towing with D-V?
One of the reasons I bought the D-V and waited for a factory trailering option is that I have a 5000# trailer to tow.
I went to the local truck accessory/hitch shop and they said they could not add an electric brake controller. They said LR changed something a few years ago and they can't make the aftermarket controller work. They said I had to go to the dealer to get the LR controller and have it installed.
I called two LR dealers. Neither have any idea of how to add a controller and don't know if LR offers such a box. They said there is nothing in their parts list or accessories catalog.
The manual says any trailer over 1654#s need the "overrun brake control".
Has anyone figured out how to add a brake controller?
Half of the reason to buy the D-V was to pull a trailer.
Old Dec 20, 2017 | 05:44 PM
Jbryan635's Avatar
Old Dec 20, 2017 | 08:15 PM
turnbaugh's Avatar
Thanks jbryan but I called etrailer early today. They said they did not have a controller that works on the DV yet. None of the manufacturers have anything that works.
If you need to tow a trailer anytime soon, there is zero evidence that a trailer heavy enough to require a brake conttoller is just not possible. I have spent a lot of time looking for a solution or an example that someone has done it.
The local shops say they can't install in new LRs without setting off fault lights.
Old Dec 27, 2017 | 01:30 PM
jaacina's Avatar
I installed the Tekonsha P3 brake controller that I had in my LR3. I used the harness from it. I believe it is plug and play, but I am not positive because I moved the wires around based on what I had read regarding the new Range Rovers. I ended up having to change the wire harness back to match the D5. I thought it was what the LR3 had.
This is what I have Etrailer.
Same brake controller and harness. Like I said I had swapped a couple of wires around in the plug on the one end of the harness here to match the new Range Rover/Range Rover Sport, but found it did not match my D5. It should fit without doing that. I used Velcro to attach under my dash.
Old Dec 27, 2017 | 01:32 PM
jaacina's Avatar
And I forgot to add, I have towed my near 7K lbs travel trailer about 4k miles with my TD6 D5. It is an awesome towing machine.
Old Dec 27, 2017 | 01:42 PM
turnbaugh's Avatar
Jaacina
good to hear the D5 is a good tow vehicle. How did you get the brake controller to work?
Old Dec 29, 2017 | 06:41 PM
jaacina's Avatar
Default Brake controller
​​​​​​My prior message has not posted yet. Waiting for the moderators approval. I used my brake controller from my LR3. Plugged right in.
Old Jan 14, 2018 | 11:48 AM
gregj's Avatar
Hi Turnbaugh,
I had the same issue and ended up going with the Tekonsha Prodigy RF wireless brake controller, it works great.
Old Jan 16, 2018 | 10:01 AM
turnbaugh's Avatar
Thanks for the replies.
We found that the wiring harness for the F150 plugs into the connector under the dash and seemed to go smoothly.
I have the brake controller installed but have not pulled the trailer yet. The shop used the tester and said it looked fine.
Old Jan 16, 2018 | 06:33 PM
gregj's Avatar
I second jaacina's comment regarding the TD6 D5 being a fantastic tow vehicle. I've made a few trips towing a 6,000 lb travel trailer and the Disco is awesome! Averaging 19 MPG traveling between the California central valley and coast.
