Towing mirrors
Old Jan 28, 2023 | 01:17 PM
LR disco 5's Avatar
Default Towing mirrors
What do you guys use for towing mirrors even though I tow a pop up its kinda hard to see around without towing mirrors anything that integrates nicely or doesn't damage the mirror would be great
Old Jan 28, 2023 | 10:09 PM
Donc98's Avatar
Milenco Grand Aeros with specific rubber pads for the Land Rover. Will not block the 360 cameras if you have that and the mirror can still fold in.
Milenco MIL-2912 Grand Aero 3 Towing Mirror
Amazon.com: Milenco MIL-2912 Grand Aero 3 Towing Mirror - Pair : Automotive Amazon.com: Milenco MIL-2912 Grand Aero 3 Towing Mirror - Pair : Automotive
pads for the mirror to prevent slipping:
https://www.boatandrvaccessories.com...ads-4-per-pack ​​​​​​​
Old Feb 5, 2023 | 11:28 AM
hiten423's Avatar
5th Gear
Off topic, but great looking discovery! What kind of wheels tires do you have? Also where did you get the front brush guard and the ones for the side?
Old Feb 8, 2023 | 04:55 PM
Donc98's Avatar
Thank you! Those are Toyo AT3 275/55 20s on RRS wheels with 30mm TF spacers. As for the brush guard and rock sliders they are from Lucky 8. Off road accessories for the D5 are a bit hard to come by and they have a good selection.
Old Feb 11, 2023 | 11:29 PM
traffictech870's Avatar
Hi there,
I'm thinking of buying a 21 or 22 Discovery and a trailer.
The size of trailer you have looks similar to one I want.
The manual says the coupling point (tongue weight??) maximum is 150kg. What's the weight GWVR of your trailer and the tongue weight you're towing?
Thanks for the help.
Old Feb 11, 2023 | 11:50 PM
Donc98's Avatar
Originally Posted by traffictech870
Hi there,
That seems a bit low. Is that with the electronic deployable tow ball that you all have on the other side of the pond? Here in the US the Si6 can tow a total of 8200lbs (37194kg) with a max tongue weight of 820LBS (371kg). My current trailer setup comes in at 4500lbs (2041kg) with a tongue weight of 395lbs (179kg). The D5 setup with a good brake controller (I use the Aussie RedArc brand) is a fantastic tow vehicle and even better (dare I say) than my Discovery 4 with the 5.0 liter that sits beside it in the driveway. Fully loaded with the family (family of 6) and the RV we comfortably head down the highway with no issues. I am looking to upgrade my RV here soon the the Sonic X line which is fully contained for off the grid camping and I do not expect issue with that one either even with about 1000lbs more in weight.
Old Feb 12, 2023 | 05:26 PM
Thanks for the quick reply.
I'm in Canada. I didn't know that UK models had a hitch ball system like that.
I'll double check with the dealer about the tongue weight.
Your trailer set up is similar to the one I want. The trailer will be 5 thousand pounds. From what you share, it sounds like the Disco V is a good choice.
Thanks for the insight.
Old Feb 12, 2023 | 06:15 PM
LR disco 5's Avatar
Im in canada too it isnt that low for the diesel its 770 lbs on the tongue you should be fine
mikelr
Nov 30, 2022 02:07 PM
houm_wa
Sep 27, 2022 01:55 PM
SoCalWiley
Sep 19, 2018 02:43 PM
09dewaed
Jun 22, 2018 10:06 AM
jcp1020
Jan 2, 2008 06:16 PM
