Toyo vs. Falken
Toyo vs. Falken
Anyone have experience with Toyo Open Country AT III or Falken Wildpeak A/T Trail? I am sure they are both fine for off-road situations, but wondering about road noise, on-road handling, etc.
Also, for anyone using these tires, what tire pressures are you running? Both on and off-road?
44psi and 50psi are awfully high and are intended for a full load with the third row. There are actually a different set of numbers in the owner's manual that says for lighter loads, you can run something like 34psi up front and 37psi in the rear. There is also a setting in the dash for switching between the two load sizes, which may or may not affect the TPMS sensors, but no, they don't otherwise have any trouble at the light load settings.
The following 2 users liked this post by AirRyan:
New2LRinCA (03-05-2021),
runNride (10-16-2020)
