Trailer Brake Controller
Old Jul 20, 2021 | 12:34 PM
LR disco 5's Avatar
Default Trailer Brake Controller
I just got back from my 3 hour camping trip and I was trying to find out does the Disco V have a brake controller built in or does it automatically use the trailer brakes???
Old Jul 21, 2021 | 06:42 AM
bkjecu94's Avatar
If your Disco has the factory hitch the wiring harness is already in place. Remove the cover under your steering column and you will see the harness attached to a support very close to the fire wall. You need to provide the brake controller, whether it be with the harness or wireless.
Here is a link to my post:
https://landroverforums.com/forum/ne...e-wire-105437/
Old Jul 21, 2021 | 11:41 PM
Seattle TD6's Avatar
very easy to install per above. It’s a Ford connection so you can order the appropriate wire harness. I believe ALL Disco V’s are pre-wired regardless of if you got the factory hitch or not.
Old Jul 22, 2021 | 07:24 AM
LR disco 5's Avatar
great thanks guys
AirRyan
May 25, 2021 11:13 PM
LandyLoverMissouri
Oct 6, 2016 07:52 PM
socuban
May 29, 2012 11:10 AM
alphawolfman
Apr 13, 2009 03:07 PM
talton
Aug 30, 2008 01:43 PM
