trailer brake question/advice
Old Apr 13, 2009 | 02:35 PM
alphawolfman's Avatar
Default trailer brake question/advice
Just bought a pop-up to pull with my 2000 Disco. I had the round pin type trailer hook-up replaced with the new style that most campers and RV's use. The shop told me I was wired for the electric brake controller at the hook up point at rear bumper but I do not see the conector or wires that should be somewhere under the dash below the steering column. Anyone ever had to search for this? If so, I would appreciate any advice. Thanks!
Old Apr 13, 2009 | 02:46 PM
There aren't any, you are wired for lights only.
I would go to a trailer repair center, not u-haul and let them tell you what you should have.
Old Apr 13, 2009 | 03:07 PM
How heavy is your pop up? There is no need for electric brakes with most of them, they only weigh 1500lbs.
I used to pull one with a Oldsmobile Cutlass Ciera with no trailer brakes.
gruehle
Jul 27, 2020 09:10 AM
TripleThreat
Apr 6, 2014 10:42 PM
talton
Aug 30, 2008 01:43 PM
Our1stDisco
Apr 3, 2008 08:50 PM
