Transmission Fluid Change
Old Nov 30, 2022 | 10:10 AM
ponderosajack's Avatar
Default Transmission Fluid Change
If anyone has changed their own transmission fluid on the D5 or other vehicle with ZF transmission: How do you measure fluid temperature after the initial fill?
This is required after the initial fill to determine if the fluid temperature is within range to top it off properly.
I have considered inserting a temperature probe or sensor into the filler hole but I'm afraid if it contacts a moving part (it is measured with engine running but transmission in park) that it will leave particles in my new fluid. Maybe no moving parts inside filler hole while transmission is in park?
I have also considered an infrared thermometer to measure the transmission case temperature but I'm not sure if it will accurately reflect the fluid temperature.
I do not believe my handheld scanner will provide transmission fluid temperature - this would be the ideal medthod.
Old Dec 1, 2022 | 05:03 AM
gmfain's Avatar
Here is the screen shot of my torque app, after adding the rover specific modules. Gear box is actually the automatic transmission temp.
Old Dec 1, 2022 | 04:54 PM
Thanks for that link and info gmfain. That certainly does provide the transmission fluid temperature.
After I posted the question I found a link to a ZF manufacturer's video showing them getting the temperature via an infrared thermometer aimed at the plastic transmission pan on a different ZF transmission so I think the infrared theremometer must be acceptable.
I don't have an Android device so I can't look into that TorquePro App yet but that's certainly an option.
Old Dec 2, 2022 | 05:09 AM
gmfain's Avatar
I think using the infrared thermometer would be a great option too.
Old Dec 3, 2022 | 05:30 PM
Here's another note for the transmission oil change: You can make sure your D5 is level when jacked up by using the In-Touch Off Road page and bringing up the display with the vehicle incline in degrees.
Old Dec 11, 2022 | 03:13 PM
I used the app Car Scanner on my iPhone and added tha PID for Gear Box Temperature and with the Header changed to 7E1 it worked great.
Old Dec 12, 2022 | 05:10 AM
gmfain's Avatar
That's great!
Triddell62
Jun 17, 2021 06:10 AM
flybd5
LR2
May 19, 2021 11:23 AM
Athana
Jun 8, 2019 10:23 AM
Externet
Sep 22, 2014 11:38 AM
mwelton
Aug 17, 2013 01:12 PM
