Water leak from roof in 2018 Land Rover Discovery HSE Luxury
Old Nov 11, 2023 | 07:36 AM
sparkster's Avatar
3rd Gear
Default pics
Old Nov 11, 2023 | 07:54 AM
BritCars's Avatar
Yes - serious water damage like flooding and immersion can be devastating for a car. But the above warning is a bit much. The Disco is made of a unibody aluminum construction so the concept of hidden structural rust in cavities that used to decimate cars from the 1960s and 1970s is totally irrelevant here.
Check for wiring corrosion if it got into the harness areas, fuse box etc. Otherwise id just fix the leak and move on.
Old Nov 11, 2023 | 03:49 PM
sparkster's Avatar
3rd Gear
Nobody will inspect the car though. I asked around ten body workshops listed on JLR website that they use for warranty work and none of them would look at the car. Only one spoke to me and said they won’t touch a car that it’s out of warranty. Perhaps they feel it is not possible to unwire every component from the roof, down the A pillars, and under the affected dashboard area and check each wire for corrosion. We do know that water is passing around the A-pillar air bags from JLR own independent inspectors report with moisture present around that safety component. Not a very comforting thought.
maximkuzmenko
Dec 19, 2019 05:28 AM
za105
Sep 16, 2019 03:28 PM
CATTIVA73
May 23, 2016 06:19 PM
AJ1
Mar 17, 2016 10:52 AM
IDAHODISCO
Feb 27, 2008 08:16 PM
