Water Leaking Into My 2018 Discovery
Old Jan 20, 2019 | 06:18 PM
maximkuzmenko's Avatar
Default Water Leaking Into My 2018 Discovery
has anyone had any issues with water leaking into the car? We got caught in quite a snow storm in Lake Tahoe during a ski weekend and to my massive surprise and disappointment the far has a massive water leak.
The water is coming in all along the passanger tide front pillar and the front eindsheild along the roofline. The amount of water coming in was even more surprising as it’s effected the dash and the whole pillar as well as part of the enterior of the roof.
I have reached out to Land Rover USA as something like this has some safety potential as this can impact the operation of the airbag located in the pillar assembly.
Let eto me know if you have a simmilar issue and how you were able to resolve it.
Thanks!
Old Jan 20, 2019 | 06:33 PM
The DareDevil's Avatar
Old Jan 21, 2019 | 08:12 AM
vulturez's Avatar
Thanks!
There was someone a few months back that started having electrical issues, only to find out water was coming in (slowly) from the same area you describe. This is a known issue as has been mentioned, I would recommend demanding they address this immediately and document it as it appears this can often lead to much bigger issues.
Old Jan 23, 2019 | 09:33 AM
AzjaST's Avatar
Yes, it is windshield, I had the same problem, it was resealed by dealer in two days. You need to address it asap as water eventually will make to the center console where bunch of electronics is located. For temporary protection you can put external masking tape on the top of the windshield as I did while waiting for appointment with loaner.
Old Jan 23, 2019 | 11:42 AM
stillruns's Avatar
Man that sucks. LR keeping with tradition in the wrong ways.
Old Jan 23, 2019 | 04:04 PM
Water ingress is actually listed on the window sticker as a standard option...
Old Jan 23, 2019 | 04:14 PM
stillruns's Avatar
Ha...!
Old Dec 9, 2019 | 02:07 PM
Ned O'Neill's Avatar
My 2018 just developed this !
Old Dec 9, 2019 | 02:39 PM
AzjaST's Avatar
When you will be picking up your Discovery from service, check rear window washer. Apparently washer fluid line for rear is running inside front pillar, when LR was removing windshield, they damaged the line. I found this couple of days later when tried to use rear wiper. Fluid start dripping from the pillar and below on passenger's feet. While they fixed leaking windshield, they broke another thing. Back to service.
Old Dec 9, 2019 | 06:07 PM
ponderosajack's Avatar
My 2018 had 3 drops of water on the inside of the windshield about 6 inches from the top right corner after I pressure washed it. I called my dealer and they have ordered a new windshield. The Denver dealer is a pretty good dealer. Due to so many D5's with leaky windshields they are backordered for a couple weeks or so. I was surprised that they aren't just removing and resealing it.
