Wildpeak AT4W 275/55R20 Rubbing
Old Apr 19, 2024 | 11:34 AM
revenazb's Avatar
4th Gear
Default Wildpeak AT4W 275/55R20 Rubbing
Just had a new set of Wildpeak AT4W installed and they are rubbing quite a bit, even without maximum turn and rubs both front and back of the wheel well. Also seems to be worse at offroad height. Any suggestions, I thought 275/55R20 was safe.
Old Apr 19, 2024 | 12:30 PM
adam5's Avatar
255/55-20
275/45-21
285/40-22
These are the standard tire sizes. You seem to have an additional .5" of sidewall
check https://tiresize.com/calculator/ to compare
Old Apr 19, 2024 | 12:46 PM
mtaylo32's Avatar
I run the AT3W's in LT at 275/55/20, but already had Johnson Rods/lift installed on my vehicle when purchased. No rubbing.
Old Apr 19, 2024 | 01:11 PM
revenazb's Avatar
4th Gear
Thanks adam5,
I knew they weren't a standard size, from reading the forums it seems 275/55/20 works except for super aggressive tires that are out of spec. Guess I should have gone with one of the proven ones.
Old Apr 21, 2024 | 07:24 AM
bkjecu94's Avatar
I run Mickey Thompson Baja Boss AT 275/55/20 with no rods and have zero rubbing. I do put Lucky 8 rods rods on when I hit the trails (I have all 3 lengths), but switch back to the OEM standard for pavement since it only takes 5 minutes.
Old Apr 22, 2024 | 01:11 PM
revenazb's Avatar
4th Gear
It seems, I just got really unlucky (read stupid), AT3W 275-55-20 seem to fit as do many others, but not the AT4W. Now I need to find a way to unload them without taking too much of a hit.
Lesson Learned
Old Apr 22, 2024 | 04:12 PM
adam5's Avatar
Originally Posted by revenazb
It seems, I just got really unlucky (read stupid), AT3W 275-55-20 seem to fit as do many others, but not the AT4W. Now I need to find a way to unload them without taking too much of a hit. Lesson Learned
no worries, things happen.
all the best mate, hopefully you're able to offload the AT4s
Old Apr 23, 2024 | 12:48 PM
RyanLR3's Avatar
Probably just me but those tires look a lot shorter in the sidewall than I'd expect from a 275/55R20. Are you certain of your wheel/tire combination? I run 275/55R20 Goodyear Duatracs and they're pretty aggressive (and noisy) and have had no issue. Could just be perspective in the photos
Old Apr 23, 2024 | 01:45 PM
revenazb's Avatar
4th Gear
You had me second-guessing myself but I checked, it is indeed 275-55-20. Partner declared situation was unacceptable and to get tires asap, so I ended BFG Trail Terrain in 255-55-r20. I didn't get to do much research, had to pick what was in stock. I'm already having nightmares of multiple flats and sidewall rips.
Old Apr 23, 2024 | 01:47 PM
adam5's Avatar
My D5 came with 21s which are likely horrendous offroad.
Bought a set of 19s from a local offerup so I can use that set for camping trips. Hopefully 19s provide enough sidewall
