2000disco2
Old May 16, 2013 | 07:48 PM
Greatpyr's Avatar
Default 2000disco2
Been lucky sssooooo far, it will fall apart now
Old May 16, 2013 | 08:20 PM
We are required to tell you that luck is fleeting; the factory oem front drive shaft has no grease fittings on some of the u joints, it will split and beat a hole in transmission; and the factory; and the factory heat gauge will point at 50% from 130 to 240F, if you want real numbers use an OBDII scanner for exact data.
