2000disco2
We are required to tell you that luck is fleeting; the factory oem front drive shaft has no grease fittings on some of the u joints, it will split and beat a hole in transmission; and the factory; and the factory heat gauge will point at 50% from 130 to 240F, if you want real numbers use an OBDII scanner for exact data.
