Combination Ignition light switch
Old May 27, 2024 | 11:04 AM
Davidsfriend's Avatar
Default Combination Ignition light switch
I'm helping my friend with a series 2a petrol engined Land Rover.
After dismantling his combination ignition/light switch, I can see that it's hopelessly worn and needs to be replaced.
The replacement parts available all seem to have the screw on connectors, whereas his has spade connections, as does the new wiring harness.
The parts supplier says it should have the screw on connections. Was there a point when Lucas switched to the spade connectors?
Because I find it hard to believe that the replacement wiring harnesses would come with spade connectors, if the original cars had the ring/ screw in type.
I have an Austin Healey of the same vintage (1966), and all the wiring behind the dash is spade type.
Thanks.
awlb
Mar 12, 2022 02:27 PM
GeorgetheLandy
Jun 14, 2021 02:34 PM
NFC
Mar 22, 2016 02:26 PM
Codyrakes08
Jun 5, 2014 07:28 PM
