coolant leak
Old Nov 29, 2005 | 04:13 PM
johnnyrockett's Avatar
4th Gear
Default coolant leak
Hey!
Anybody have any experience with the metal lines that run from top to bottom of motor and leaking coolant?
Everything else has been checked and I can see it dripping when I am parked
Are they hard to replace or is there a fix?
Please help!
Thanks
Old Nov 29, 2005 | 05:33 PM
Randy Lover's Avatar
Default RE: Clicking sound when 4wetc is engaged in dash?
are u sure its not the TC kicking in to keep you moving ?
Old Nov 29, 2005 | 09:08 PM
4th Gear
It might be but is it supposed to make a noise?
Does the light just go on for a seconnd or 2 and then go off?
do they all do this?
Thanks for the help
Old Nov 30, 2005 | 01:13 AM
Benhamtroll's Avatar
The TC in my 2000 makes a clicky noise when it engages, at least when it has to work seriously in snow or ice. As far as I know it's normal.
Old Nov 30, 2005 | 04:44 AM
yeha weve got a 2003 disco and everytime the TC kicks in its followed by i "grinding" kinda noise and the "TC" light
its normal if i its what i think it is
Old Nov 30, 2005 | 12:52 PM
4th Gear
Thanks everyone for the info!
Old Dec 2, 2005 | 09:41 PM
4th Gear
Default coolant leak!
Hey everybody!
Any one have any experience with the metal lines that go from the top of the motor to the bottom and carry coolant?
I think mine are leaking! Little drips everytime I park!
Already did the water pump ! all other hoses look good!
Are they impossible to fix?
Do they rot?
Any help would be appreciated!
Thanks.
Old Dec 7, 2005 | 01:39 AM
ferrelltodd's Avatar
Default RE: coolant leak
I have a 2001 Discovery and am having a similar issue. I see coolant on the bottom of my engine and on the lines. The leak is not constant, it is intermittent. I sat underneath the car for about a freakin hour trying to figure out where it was coming from. I thought it had to be the aluminum lines as you did. However, I now think that it is the Cold Level overflow line. I think the change to the cold weather has slowed the flow of coolant throught the block and my cold level resevoir is overfilling at times. When it gets too high, I think it "spits" out the excess then stops. When it does, its hitting the frame etc and splattering all over the bottom of the engine. Check around the cold level resevoir and see if you have any coolent around it. Also, my check engine light recently came on. The code is a "speed sensor" fault code and wouldnt you know it, the speed sensor is directly below the cold level resevoir and coolent is soking it.
Old Mar 12, 2006 | 09:44 PM
porschapete's Avatar
[sm=dontgetit.gif] I have the same thing is going on with my 2000 range over......why is it leaking and what is that tube.............[sm=feedback.gif]
Old Feb 6, 2009 | 05:12 PM
prenault11's Avatar
I have a 2001 Landrover Dicovery II.
Since the past few months I have discovered a coolant leak that leaves a stain whenever I park for a long period of time, and I have to fill the overflow tank a few times a month.
I have had both the radiator replaced (leak found) and the thermostat.
Now I still cannot find were the coolant is coming form. My temperature gauge will stay in the middle after a few minutes of drive time, never goes above the middle. But yet occasionally my temperature light will come on then go off.
This happened today as I was going through the car wash. But it went away the minute I left.
I am puzzled.
I cannot find any leaks around the head gasket, but the heating plate on the throttle body has what looks to be a leak. I do not see a lot of coolant around that area to warrant that as being the problem.
However I feel this may be coming from the front, since that is were I find the stains.
Can someone help with a suggestion?
Thanks
ZMonet
Jun 24, 2016 04:00 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
nolabrooke
May 21, 2010 09:33 AM
lipadj46
Jul 8, 2009 07:41 PM
