D2 owner from Colorado
Old Sep 27, 2013 | 06:14 PM
Rtp97's Avatar
3rd Gear
Default D2 owner from Colorado
Hi all, I've had my 2004 D2 since 2010 but I am new to the forum. In the last 2 months I've put a 2 inch spacer lift from Toddco suspensions, new Terrafirma All-Terrain shocks and steering damper, and a set of 5 new Goodyear Duratracs (275/65 18). I just replaced the rear brakes with Brembo rotors and Akebono pads hoping to eliminate some of the dust, fronts will have to be done soon. I'm hoping to test my new setup on the trails soon!!
Old Sep 27, 2013 | 08:54 PM
Welcome. Please check your front drive shaft, oem model does not have grease fittings on double end, it snaps, it flails around, it bashes hole in transmission case. Rebuild article in our tech area, or aftermarket replacement.
Old Sep 29, 2013 | 08:18 AM
Those spacers are not made to be a lift with a stock warn out factory suspension. As soon as you can go to a good lift with coils and shocks cause what you now have is an even more top heavy unstable vehicle when off road.
Old Oct 7, 2013 | 10:01 AM
denverdisco1's Avatar
Default Hello
I'm in Edgewater near Denver, nice to meet you
Old Oct 8, 2013 | 05:35 PM
Rtp97's Avatar
3rd Gear
Thanks for the input guys! I'll try and get those items taken care of asap.
Old Oct 8, 2013 | 05:37 PM
Rtp97's Avatar
3rd Gear
Hi Steve, nice to meet you too. I am in Colorado Springs.
Old Oct 18, 2013 | 03:40 PM
1strover01d2se7's Avatar
4th Gear
I'm also in co springs, not as many fun things to do locally in the rover since all the trails are closed due to trail damage from flooding
ZachJohnson
Jul 10, 2015 07:50 AM
jmiles
Oct 29, 2013 11:17 PM
denverdisco1
Oct 4, 2013 12:55 PM
bigbalu
Feb 8, 2013 01:51 PM
alex of minnesota
Jun 30, 2007 11:29 PM
