Need help diagnosing strange sound at start up
Old Jan 5, 2020 | 05:35 PM
MotorCityRover's Avatar
5th Gear
Default Need help diagnosing strange sound at start up
My 2006 RR HSE with 133K miles recently began making a high pitched screeching sound upon starting the engine. Happens on cold and warm engine starts. Sound / noise lasts anywhere from 2-5 seconds then disappears. Sounds electronic (as opposed to mechanical) and sounds like it’s coming from inside the cabin (as opposed to the engine bay). Sound doesn’t correspond to acceleration or RPMs. Don’t think it’s radio related either. No warning lights or error messages. Vehicle runs great otherwise. Has anyone experienced this type of sound or have any thoughts as to what’s going on? Any help would be appreciated…
Old Jan 6, 2020 | 11:19 PM
sandplasma's Avatar
I think I've read that PCV Valve sounds like an airplane for a few seconds. May want to look into that. Many cars also make a screeching noise if the belts are slipping, especially when starting them. You could try spraying some WD40 on the belts to see if the sound goes away.
Old Jan 7, 2020 | 04:03 AM
5th Gear
I appreciate the tip, thanks! I actually think I ‘may’ have figured out the mystery. My “check tire’ light came on yesterday. I figured I was low on air or had a faulty TPSM. All 4 tires had proper inflation. I figured I’d check the spare. It was at 30 lbs. I aired it up and what-da-ya know...the light has stayed off and the shrill sound has stopped. I’m guessing it was a warning chime that has gone wonky. Sounds horrible but since I’ve aired up the spare, it hasn’t repeated.
Old Jan 8, 2020 | 12:18 AM
sandplasma's Avatar
I would've never guessed it! Glad it was an easy fix.
3rd disco
Sep 10, 2016 05:33 PM
Nonoydj07
TEST FORUM
Jul 4, 2016 05:49 PM
Drubie22
Sep 18, 2014 05:50 AM
mikep70
Dec 6, 2013 03:22 PM
tobob1
Sep 11, 2006 09:14 AM
